203 stat in
Old Feb 18, 2008 | 10:09 AM
Cuda_jim's Avatar
Cuda_jim
I personally wouldn't bypass the cooler in the rad. It helps get the trans up to temp quicker, especially if you are running a larger than OEM air to liquid cooler in front of the rad. Too Low temps are just as bad as high. The oil needs to get hot enough to burn off the condensation and get the additive package working + the internal tolerances are designed for certain temps. It's like running an engine with no stat. The oil turns white and foamy from condensation. and shortens the life of the engine.
You can't compare OBS trucks to the Newer ones, they did away with the rad cooler because they have thermostats in their huge air to air cooler system.
Liquid to liquid coolers are much more efficient than an air to liquid. The coolant temp in the radiator very seldom sees the thermostat temp rating. With a 203 stat I doubt you would see 180 temp at trans cooler. I will let you know shortly, a new 203 stat is going in.
My 2 cents
Old Feb 18, 2008 | 11:30 AM
MADVAN's Avatar
MADVAN
My 2 cents
Cuda
I agree with you as far as winter use. Not summer.
Also it really has nothing to do with the condensation issues. Even at 180*F you still dont remove water from the fluid. Water changes state at 212*F.
One can only guess what the fluid temp is at the clutch, drums, bearings ect.
In general if you have your temp sender in the pressure port the TFT average is 20*F hotter than what you see on the gauge.
99% of the time if you remove a stat from a motor it will run hotter/overheat.
Just takes longer for it to happen.(summer)
You want to run a diesel as hot as you can 200+. Not the trans.
Bill
Old Feb 18, 2008 | 03:11 PM
MikeFromShiloh's Avatar
MikeFromShiloh
QUESTION - I have a 95. Does that mean the Napa stat will work fine? or is there somehting I have missed?
Old Feb 18, 2008 | 03:42 PM
MADVAN's Avatar
MADVAN
If you still have the short t-stat pump you can.
Bill
Old Feb 18, 2008 | 06:37 PM
F0rdF0rever's Avatar
F0rdF0rever
Speaking of trans temps I won a 6.0 trans cooler last night on ebay. That should keep me cool in the summer months.
Old Feb 18, 2008 | 07:13 PM
Fullcrew7.3's Avatar
Fullcrew7.3
I went to order mine today and ran into a couple problems on the site. I'll have to call there tomorrow and see.....
Old Feb 18, 2008 | 08:08 PM
Flea's Avatar
Flea
As the temp. goes up the perf. goes down, correct? We want to keep the temp. down at some spots but up in some others.
For someone who doesn't want to trade out stats every six months, would you all prefer to leave in the orig. or not.
I have a 203 and I run veggie. I don't pull a lot and I am running the black tru-cool tranny cooler. I don't have the 203 installed yet. Would you all install it?
What are the downfalls?
I don't have a intercooler, what problems will I have?
thanks,
Fletch
Old Feb 18, 2008 | 08:14 PM
tjbeggs's Avatar
tjbeggs
You won't have any problems with it installed. For trans you want cooler temps but for the engine you want hotter temps for the coolant.
Old Feb 18, 2008 | 08:15 PM
Flea's Avatar
Flea
So, do we need to install bypass lines or how to we handle this in the summer?
Old Feb 18, 2008 | 08:16 PM
MADVAN's Avatar
MADVAN
X2
Bill
Old Feb 18, 2008 | 08:17 PM
Flea's Avatar
Flea
Bill what kind of bypass lines have you installed on your tranny cooler?
Old Feb 18, 2008 | 10:01 PM
Flea's Avatar
Flea
Maybe we should bump this up?
I am still on edge about what to do. After all the tranny is the weakest link is these trucks is it worth the extra. I guess I need gauges.
Old Feb 19, 2008 | 05:10 AM
  #28
1997stroker's Avatar
1997stroker
Madvan,
Can you tell exactly how you are set up as far as bypassing the trans cooler in the summer. It sounds like you have two valves installed where the hoses go into the radiator with a small hose to create a loop. I received notice my 203 stat is at the post office, yesterday. I want to install it because it seems to help a lot with smooth engine acceleration. BUT, I pull a 38' horse trailer and don't want to possibly do damage unknowingly to the transmission. I have 5 speed manual, no gauges to monitor temperatures, except factory ones. Also when you bypass the cooler in the radiator, do you have another trans cooler somewhere else? I'm sure this is probably at a very basic level for some of you. I just want make sure I fully understand what I'm fixing to do and it's side effects. I want to install the 203 stat but don't want to harm anything else. Thanks for the time ,CJ
Old Feb 19, 2008 | 07:05 AM
  #29
bkcowboss's Avatar
bkcowboss
Originally Posted by 1997stroker
Madvan,
CJ with a ZF5 Five speed tranny there is no trans cooler, yours and my trucks are very simple when it comes to the radiator portion, all we have is the engine coolant radiator in the grill. The auto trannys have a smaller radiator for tranny fluid that is a fluid to air cooler, and then the discussed fluid to fluid radiator is inside of the engine coolant radiator. You can install the 203 degree thermostat with no ill effects on your tranny.
Old Feb 19, 2008 | 08:34 AM
  #30
MADVAN's Avatar
MADVAN
Seems i started a slight pannic over this.
The 203 stat is not going to hurt your trans. It will/can make it run hotter in the summer time. It does not need the heat. Fords overheat to set a code is 270*f at the TFT. On your gauge thats about 250*F "overheat". My statement is for trans and fluid life. The cooler it is the longer it will last.
As a test come summer just bend up a small piece of 5/16 or 3/8 (you could have either) hard line to mimic the liquid cooler. Pull the lines off the rad and install your hard line with the clamps.
Testing has been all over the map. Some have no change in the temp, some run cooler an in SD its been found that they will run hotter when removed. The bottom of the rad is the coolest part of the cooling system.
No 2 trucks are the same after mods to the truck (motor,trans,tires,ect). And how you use the truck.
I have found 15 to 20*f cooler fluid with it removed. ("summer").
I like to see 160/180 average temps with syn fluid for a long trans and fluid life.
Bill
