I think my driver side door switch is going bad causing the "Door ajar" light to come on sometimes; and other times causing the cab light to stay on after I get out. Can someone please tell me where it is located and how to replace it?
Spray WD40 in where the door lock is on the door. Work it in. Should loosen up the door switch....
hey Doug, if it happens again just replace the sensor. it is in the door by the latch, i've replaced 2 in 2 different SD's and i believe they're about $8 at the stealership.
