silence keyfob
This info below is from my 1995 manual. The 2001 manual shows the alarm system to be significantly different from the 1995 and I suspect that the 2006 may be more like the 2001. I am not able to find a procedure for changing the horn response in the 2001. Will keep looking. Posting the 1995 in case any body else is interested.
There are "Worlwide Alarm Configurations" which determine the response of your exterior lamps, horn, theft LED, and alarm triggers. The North American protocol flashes the lights, sounds the horn, and flashes the theft LED for 2 min 45 sec. and has 3 alarm triggers. The Japanese protocol does not sound the horn or flash the exterior lamps. It does flash the theft LED for 2 min 45 sec and has 3 alarm triggers. In addition, the Japanese option has no horn chirping when you press the LOCK on the fob & there is no panic function at all.
To change your programming:
1. Make sure your anti-theft system is not armed or triggered, that the ignition is off and all doors closed.
2. Turn ignition key from OFF to RUN.
3. Press the door power unlock button 3 times.
4. Turn ignition key from RUN to OFF.
5. Press the door power unlock button 3 times
**Turn ignition key back to RUN within 30 seconds of step 2.
If the receiver assembly has successfully entered the enable/disable mode, it will lock and then unlock all doors. While in the enable/disable mode, the receiver assembly will not have any other functionality except for enabling/disabling features.
The following sequence will toggle the feature to either the enabled or disabled state opposite of its current state:
Press the door power unlock button the number of times associated with the feature you wish to enable or disable.
Autolock/relock-1 press
North America protocol--5 presses
Japan alarm--9 presses
The system will confirm the altered feature by chirping the horn the same number of times as the number of unlock presses registered. An additional long honk will occur after the horn chirps if the feature has been enabled. No horn honk will follow the horn chirps if the feature has been disabled.
After a horn chirp sequence has occured in the enable/disable mode another enable/disable sequence may be performed.
To exit the enable/disable mode, turn the ignition to OFF (or allow 5 minutes to pass after entering the enable mode). Upon exiting, the system will confirm the exit with a honk chirp if a feature has been changed.
The receiver assembly will keep its enable/disabled settings anytime battery voltage is disconnected and reconnected to the control module.
Hope this helps,
Ed
Last edited by ed-g35; Feb 16, 2008 at 01:51 PM. Reason: Added info regarding model years.
