programming keyfob help - 03 aviator
Old Feb 4, 2008 | 04:38 PM
rel3rd's Avatar
rel3rd
(arm in cast, so forgive any grammar mistakes)
i tried to program my new keyfob today, on my 2003 aviator.
owner manual says cycle ignition key from on to lock position 8 times, stopping at on position, then doors should lock and unlock to tell you that you are in programming mode
i've tried it several times and cannot get into programming mode for some reason
any ideas?
Old Feb 4, 2008 | 06:23 PM
winfordr's Avatar
winfordr
Are you using the new key? You will have to use a key that is already programmed to get into the programming mode, and, in fact, you will need another good key in roder to prgram a third.
Old Feb 4, 2008 | 09:18 PM
rel3rd's Avatar
rel3rd
i'm not trying to program a key...i am trying to program a new keyfob, aka a remote.
my wife lost one and owner's manual says you can program up to four at a time, but you have to get the car into "programming mode", which is where i am having a problem
Old Feb 4, 2008 | 09:23 PM
winfordr's Avatar
winfordr
Sorry, I missed your point there. Does it tell you to make the on-off cycles in a specific number of seconds?
Old Feb 4, 2008 | 09:31 PM
rel3rd's Avatar
rel3rd
yes.
it says eight on-off cycles must take place within 10 seconds, which i made sure of.
at that point, according to manual, doors should lock and unlock (on their own) to verify that you are in programming mode...<<<<----that part is not happening, which tells me the vehicle isn't going into programming mode.
until it does, evidently, the new keyfobs cannot be re-programmed
Old Feb 4, 2008 | 09:38 PM
winfordr's Avatar
winfordr
OK, sorry for the bad info before, but I just looked up my mountaineer instructions, and my book says: swithch from lock to ACC first, then switch from ACC to ON 8 times, and the doors will unlock, etc to indicate programming mode.
Are you sure your book doesn't say ACC instead of Lock? It could be different from mine, but mine (Mountaineer) says ACC.
Good luck anyway!
Old Feb 4, 2008 | 09:57 PM
rel3rd's Avatar
rel3rd
you'd think they be the same....if you go to:
https://www.fleet.ford.com/maintenan...ls/results.asp
2003 lincoln aviator then to page 162, it says position 1 (lock), to position 3 (on)...this is the same instructions as my owner's manual, but for the heck of it, i'll try your way tomorrow and see what happens
Old Feb 5, 2008 | 06:03 PM
rel3rd's Avatar
rel3rd
well....finally figured it out....
doors have to be "electronically unlocked" first, which in this case means, opened via the door panel mounted lock button and not using the existing and functional keyfob...
Old Feb 5, 2008 | 07:46 PM
winfordr's Avatar
winfordr
Wow! was that anywhere in the instructions?
Old Feb 5, 2008 | 08:31 PM
rel3rd's Avatar
rel3rd
sort of...
step 1. make sure vehicle is electronically unlocked
i wrongly assumed that if i unlocked doors like i do any other day, with the keyfob, that the doors were in fact "electronically unlocked"....little did i know that wasn't the case...
thanks very much for the help
i have found (and not just here) that with this vehicle any online technical support or help is very, VERY limited. it seems most everyone is more concerned with their shiny new overpriced rims, or what kind of wax to use, than with trying to help someone with an actual technical problem....
Patriot_RAM
Oct 31, 2023 04:16 PM
airrikk17
Apr 4, 2013 03:14 PM
donaldgoss
1997 - 2003 F150
Dec 7, 2010 03:29 PM
joe shmoe
Jan 4, 2010 07:07 PM
97f150sk
Electrical Systems/Wiring
Apr 20, 2004 07:26 PM
