C4 vs C6
Old Feb 15, 2008 | 02:19 PM
dragogt's Avatar
dragogt
C4 vs C6
hey guys, I'm swapping a 302 to 351 in my bronco, but my motor is a Mercruser from the 70's. I know it has to be a 28oz flexplate, but will one from a C4 bolt to the C6 T/C in my truck?
Old Feb 15, 2008 | 02:52 PM
projectnitemare's Avatar
projectnitemare
All of the ones I ever come across won't interchange. Maybe someone else might have some better insight.
Matt
Old Feb 15, 2008 | 05:39 PM
dragogt's Avatar
dragogt
so then, do you think that one from a truck would work?
Old Feb 16, 2008 | 02:52 PM
stuart1's Avatar
stuart1
302 has the same bolt pattern as a 351 C or W.
The M engine will not work.
Old Feb 16, 2008 | 03:01 PM
dragogt's Avatar
dragogt
it's a W the thermostat housing's on the intake, and the fuel pump bolt's are side to side.
https://www.ford-trucks.com/forums/7...late-help.html
Old Feb 17, 2008 | 10:07 AM
littleme13's Avatar
littleme13
im gonna say it will bolt up but to check just try and bolt it up before you put the flywheel on the engine just to make sure if it doesnt then you know its wrong before you have to pull the engine back out..
tony
Old Feb 17, 2008 | 10:14 AM
dragogt's Avatar
dragogt
problem is the 351's sittin in my garage right now and I haven't pulled the other one out yet. but I figured I'd do something like that.
miottimouse
Oct 17, 2014 07:32 AM
kentruckf100
Oct 1, 2014 09:07 AM
BlackLabel78
Jun 1, 2009 12:30 AM
Polkat
Jan 10, 2006 12:39 AM
trailman
Nov 3, 2004 12:21 PM
