Another 6637 & temp sensor ?
Old Feb 15, 2008 | 07:46 PM
F350-6's Avatar
F350-6
Originally Posted by Meatco1
This is exactly what I did (with a 3.5" long, 4" diameter elbowed exhaust pipe). And, actually it does look like a factory job.
I would be happy to post a photo, but am computer challenged!! Sorry
Drilled a hole in the pipe, installed a rubber gromet, along with a dab of silicone, zip tied tight until dry (then cut & remove zip tie), inserted sensor, installed the wire wrap (like factory) over wires, and, Walla !!
It's done
Does not leak, looks like OEM, and simple
Richard
Does your rubber grommet fit nice and tight. I personally would not trust a dab of silicone on dissimilar materials to provide an airtight connection.
Old Feb 15, 2008 | 07:56 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i just stuck my iat in the inner fender
Old Feb 15, 2008 | 08:34 PM
Meatco1's Avatar
Meatco1
It is absolutely tight. There is no leak whatsoever!
Richard
Old Feb 15, 2008 | 08:51 PM
sflem849's Avatar
sflem849
Not to be a _____, but how many people have had their 6637 fall off their pipe??? (Pete has several times and I have heard of others) So I guess I don't see this as a huge "dirty air inducing" problem. (at least not any worse than doing the 6637) I have never seen anyone silicone between two pieces of silicone?!? Most of the time it is used between dissimilar materials.
Old Feb 15, 2008 | 09:10 PM
Meatco1's Avatar
Meatco1
Guys,
There is no pressure blowing the gasket, or sensor out. The flow is going the other way, remember the turbo is sucking air thru the filter assembly, hence the the gasket, and sensor are being pulled tighter, not being pushed out.
Do what you wish. Use your own imaganation as to how to connect, or not connect the sensor. But, for me, this works just fine!
Richard
Old Feb 15, 2008 | 09:35 PM
F350-6's Avatar
F350-6
Sorry. I've just got a personal distaste for silicone in most applications I'm used to dealing with. By dissimilar I was referring to items with different expansion/contraction rates in the presence of heat. Silicone has great elastomeric and cohesive properties, but in my opinion leaves something to be desired in the adhesive category.
It might work fine in this application, and as long as the rubber grommet fits tight there should be no worries.
Old Feb 15, 2008 | 10:02 PM
00Dave's Avatar
00Dave
OK. I think I'll try to mount the air sensor in the 4" pipe. Sounds like all I need is a grommet and a good tight fit to ensure no infiltration. Kwik, I like your idea of a vacuum gauge! Thanks to all of you for your ideas and replies. Most beneficial!
Old Feb 15, 2008 | 10:20 PM
Meatco1's Avatar
Meatco1
F350-6:
I'm not trying to convince you to do this. I'm just stating a fact that this setup does not leak.
I'm a big believer in "Each to his own"
Richard
Old Feb 16, 2008 | 07:43 AM
sflem849's Avatar
sflem849
Yeah, I thint the grommet is plenty. The silicone is just backup.
bigcountry1009
Oct 30, 2014 08:48 PM
Orezona
20
May 16, 2010 01:58 PM
squaredancer
Mar 13, 2009 11:01 AM
clydesride
18
Oct 12, 2006 01:24 PM
maevans
Apr 27, 2006 10:51 PM
