6637 questions
Old Sep 27, 2006 | 08:22 PM
clydesride's Avatar
clydesride
6637 questions
Hi guys, just installed the Kwik 6637 mod, removed some of the air-box and drilled a 3/4" hole in the blank end for the filter minder, attached the filter direct to the intake tube, just remove the entire tube and a little WD-40 and the filter slips right in, quick clamping and poof we are done!
Had a question about the "other sensor" I found attached to the stock box? What does it do? What should I do with it? I just left it sitting on some of the wiring harness near-by is it ok? I was also wondering about the filter it-self, will it be a problem getting wet from spray from underneath? I will get a "Pop" pre-filter on it soon but was a bit concerned about the water/snow question.
Thanks for "listening"....
Dave
Old Sep 27, 2006 | 08:24 PM
empiretc's Avatar
empiretc
Are you talking about the "restriction reset" on the front of the box?
looks sort of like a fuel bulb
Old Sep 27, 2006 | 08:26 PM
Uzumati's Avatar
Uzumati
That is the intake air temp sensor some people tye wrap it to the filter neck. Keep it as close to the filter as posible and as far away from engine heat as possible
Old Sep 27, 2006 | 08:28 PM
MAKO314's Avatar
MAKO314
I ziptied it up out of the way,i beleive its the intake air temp sensor
Old Sep 27, 2006 | 08:29 PM
MAKO314's Avatar
MAKO314
oops he beat me to it
Old Sep 27, 2006 | 08:30 PM
erik_bishop's Avatar
erik_bishop
It is an air temperature sensor.
just zip tie that sensor to the master cylinder lines, it will end up close to your filter but not touching it.
it wont get wet from spray from underneath. I have had mine installed for 4 or 5 months now and have driven in a couple good rain storms and its still good and dry.
Old Sep 27, 2006 | 08:32 PM
erik_bishop
wow i must type real slow, thought i was going to be the first to try and answer these questions.
Old Sep 27, 2006 | 08:46 PM
empiretc's Avatar
empiretc
me too, what a great forum
Old Sep 27, 2006 | 09:40 PM
Brian0445's Avatar
Brian0445
i installed the kwik 6637 filter a few weeks ago, faily simple but no matter which way i try to put the filter in it seems to touch the master cylinder and i get a vibration from the air filter transferring to the master cylinder and feel it in the petal while braking. any solutions..... but i love the sound!
Old Sep 28, 2006 | 08:48 PM
clydesride's Avatar
clydesride
Thanks guys... I will ty-wrap it near the master cyl! Any ideas about the water/snow issues?
Old Sep 29, 2006 | 02:17 AM
kennedyford's Avatar
kennedyford
Ive had mine on for over 100k, no issues here, especially if it sits right behind the battery and is sheltered from the bottom by the inner fender well.
Old Sep 29, 2006 | 06:54 AM
Kwikkordead's Avatar
Kwikkordead
When I still had my 6637, I extended the wires for the intake temperature sensor and installed it in the end of the filter.
Old Sep 30, 2006 | 09:07 PM
clydesride's Avatar
clydesride
Thanks guys... I might even tryo to mount the temp sensor beside the filter minder.... should fit, it is a big filter. I wonder Kwik, what are you running now for yours?
Dave
Old Sep 30, 2006 | 09:30 PM
Kwikkordead
Dave
I have the Ford AIS now.
Old Oct 1, 2006 | 09:01 PM
clydesride's Avatar
clydesride
I might look for it up here some time, no idea how much or anything but, seems like a good unit and might be a good safe addition.
Dave
