MPG dropping
Old Feb 13, 2008 | 10:41 PM
Cpuslayer's Avatar
Cpuslayer
MPG dropping
I seem to loosing some MPG on my 2001 ranger 4x4 4.0L. I use to average 16mpg with lumber racks installed which is still low, but now the last couple of tanks I am hitting 13.5 MPG and i'm easier on the gas. It is 30-40F here and I am using the same gas stations as before.
Before my last fill up with gas, I changed out spark plugs, changed oil, idler pulley, tensioner, changed transmission filter & oil, fuel filter, air filter is clean, and it runs good. It still didn't increase the MPG. In past winters my MPG went up because i'm easy on the throttle, but now it has gone way down. Any ideas?
Old Feb 14, 2008 | 12:10 AM
Bear River's Avatar
Bear River
Former ******
Bad thermostat or ECT can cause poor economy by fooling the ECM into thinking the engine is colder than it really is. It will run in warmup mode longer, or stay in warmup mode all the time.
If the O2 sensor hasn't been replaced in the last 80,000 miles, it probably wouldn't hurt to replace it too. Besides, if you leave them in too long, they get stuck and won't come out.
Old Feb 14, 2008 | 05:10 AM
wendell borror's Avatar
wendell borror
Also alot of states run winter blends, they pollute less but get worse mpg as well. I allways get worse mpg in the winter here in Ohio than I do in the summer.
Old Feb 14, 2008 | 09:01 AM
sfcwoodret's Avatar
sfcwoodret
Try a tank of premium gasoline and see what it gets on that. That may tell you something.
Old Feb 14, 2008 | 09:41 AM
Bear River's Avatar
Bear River
Former ******
Premium gasoline won't help. Premium gasoline isn't better, its just higher octane. Higher octane is harder to burn, so if anything, it will reduce the fuel economy of an engine that does not have a high enough compression ratio to burn it. And it will cause carbon deposits, which can gradually cause additional problems. Use the octane rating recommended in your owners manual
Old Feb 14, 2008 | 12:07 PM
nelstone74's Avatar
nelstone74
Check the tire air pressure. The pressure can drop as it gets colder
Old Feb 14, 2008 | 03:39 PM
wtroger's Avatar
wtroger
You are seeing the results of the addition of Ethanol to your gas as an octane booster. They had to quit using mtb. Almost all gas has ethanol in it now and it will hurt fuel mileage.
Old Feb 14, 2008 | 08:54 PM
Cpuslayer's Avatar
Cpuslayer
Tire pressure are at recommended, I checked before I filled up on my last test tank. I never thought about Ethanol, but I cant imagine that it would decrease my MPG that much. How do you test the ECT and oxygen sensors to see if they are good, i'm not throwing any codes.
onug
Modular V10 (6.8l)
23
Jun 10, 2012 10:10 PM
QUINCE
General Diesel Discussion
Nov 6, 2008 09:53 PM
robertbucher
2004 - 2008 F150
16
Sep 11, 2008 09:31 PM
BowDown
106
Apr 2, 2006 06:49 PM
Maxdog
New Hampshire Chapter
May 10, 2004 12:29 AM
