Coolant Filter Leaking
Old Feb 13, 2008 | 08:15 PM
jmaskew's Avatar
jmaskew
I just installed the Dieselsite Coolant bypass filter last Friday. I noticed after a couple of days it was leaking a little; just a few water spots on the filter and below on the fan, etc. I took the filter off and retightened it, hand tight and about 1/2 turn or so with a filter wrench. It is still leaking a little bit. Anyone else experienced this?
Old Feb 13, 2008 | 09:21 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Not I. Make sure the hose clamps at the filter housing are tight. It could be possible some coolant is leaking past one of the clamp fittings and flowing down onto the filter. The only thing I can think of unless the filter gasket is cut.
Also, did you use pipe tape on the filter housing fittings? If not, that could be source of your leakage.
Last edited by Powerstroke_wannabe; Feb 13, 2008 at 09:23 PM. Reason: Add more info.
Old Feb 13, 2008 | 10:06 PM
jmaskew's Avatar
jmaskew
The hose and clamps are fine. I used white plumbers tape on all the fittings and they are holding up just fine. It is definitley leaking from the filter. Maybe I should just get a new one since they aren't too expensive. I was just wondering if anyone else had experienced this. Thanks for the reply.
Old Feb 14, 2008 | 09:12 AM
Benchwrench's Avatar
Benchwrench
is the filter base machined where the filter seals, or is it cast?
if you still experience a leak after the filter R&R, you'll know the base or a related fitting is the culpret.
Old Feb 14, 2008 | 08:38 PM
diesel_dan's Avatar
diesel_dan
did you lube the gasket before installing the filter? (very important the 1st time...)
Old Feb 14, 2008 | 10:15 PM
jmaskew's Avatar
jmaskew
Yes, I turned it a little more with the filter wrench and it's ok now. I was a little nervous that I might "overtighten" the filter that I didn't tighten it quite enough. Won't do that again. Thank you for all the replies everyone.
Old Feb 15, 2008 | 07:29 AM
69cj's Avatar
69cj
After contact you can get a full turn almost on these filters without hurting them.
Old Feb 15, 2008 | 06:09 PM
jmaskew's Avatar
jmaskew
Thanks for the reply, next time I will know better. I remember on my old '95 7.3L I would hand tighten the oil filter then give it about a half turn with the wrench and all was good.
vlietracer64
Dec 29, 2012 09:05 AM
wulfman
Jul 11, 2011 10:52 PM
biawokauns
Apr 27, 2009 10:19 PM
NS F250
Apr 22, 2007 07:46 PM
TexasGuy001
Jan 7, 2006 10:01 AM
