Climate Control
Old Feb 12, 2008 | 10:32 PM
mtford's Avatar
mtford
Climate Control
I have a 02' PSD 4x4 limited X and noticed the climate controls turn the blower on high as soon as the truck is started cold. Most vehicals I've had had a sensor for engine temp I guess which kept everthing off till the cooling system was warm enough to do any good. Is this operation the way it was designed (boo!) or is this a problem that can be fixed if a person has a large wad of money?
Old Feb 13, 2008 | 11:16 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II
Just fixed the same thing under warrenty
I just had the same problem fixed on my '06 SD F250. Climate control developed a mind of its own and wanted to blast you out of the truck.
When I got my repair invoice it indicated the "CONTROL" was replaced and showed a part number. Being curious I looked the part number up and the price was $30.something. Seems to be a cheap fix but I don't know where the part is located in the dash. There was no picture for that part number either. I can't even tell you what it looks like.
I don't have the invoice with me but will take a look and post the part number for you. Don't know what years its used in but probably the same for all climate controls, hopefully.
Hope this helps. Its a start anyway. Ernie.
sig40
Jun 18, 2020 05:01 PM
CRobertson
May 27, 2013 10:43 AM
militarymonark
May 15, 2012 09:52 PM
JD603969
2004 - 2008 F150
May 3, 2012 06:01 AM
bgalaxy67
Feb 26, 2004 04:06 PM
