Intake clearance
Old Jan 12, 2003 | 09:59 AM
Hidome's Avatar
Hidome
Intake clearance
Hey all,
I have read on here about people having problems getting there intakes to seal, if their heads have been shaved. I shaved my heads .020, will I need to shave my intake as well?
Old Jan 12, 2003 | 10:42 AM
shazam's Avatar
shazam
Intake clearance
[updated:LAST EDITED ON 01-12-03 AT 11:44 AM (EST)]Well the best thing to do is test fit the intake before you put it back together.
With the engine on the engine stand place the intake on without any gaskets and take a light and check for air gaps between the heads and intake. They should fit flat top to bottom. If there is air gaps(Say it touches at the bottom but has an 1/16" gap at top) then you'll have to have the intake milled to get a flat fit.
Don't worry about the end gap you'll be using Silicon on those.
Old Jan 13, 2003 | 02:01 PM
grclark351's Avatar
grclark351
Intake clearance
how is cutting the deck surface of the heads going to change the angle of the intake mating surface? even if the intake mating surface isn't perpendicular (double word score)to the deck surface, the angle will be the same. i thought the reason to cut the intake was to maintain port and bolt hole relationships?
Old Jan 13, 2003 | 02:13 PM
Ford_Six's Avatar
Ford_Six
Intake clearance
One side may have been cut a hair more than the other, but also what is usually cut on the intake is where it rests on the block. It is also possible for the intake to be warped, causing a lack of sealing. Most good machine shops cut the top of the block also, though.
Old Jan 13, 2003 | 03:14 PM
Torque1st's Avatar
Torque1st
Posting Legend
Intake clearance
willpjones
Apr 2, 2016 10:37 AM
greentruck72
May 4, 2015 04:02 PM
73 ford guy
Apr 21, 2010 10:51 PM
FordCardinal
Aug 15, 2004 03:31 PM
walt80
Dec 17, 2003 10:38 AM
