air bag deactivation switch
Old Feb 11, 2008 | 10:20 PM
goodwrench's Avatar
goodwrench
My 99 ranger has one and often wondered what the procedure was to use it. When i played with it you stuck the key in and turned it and then it springs back. I read the owners manual but it is not very clear. So what is the procedure for turning off the passenger air bag? Do you have to have it running and turn the switch with a second key? Or do you do it before starting the motor? Does it reset every time the switch is turned off? Or am i totally off?? I want to know how to use it if i ever want to or need to..
LAter!! chris
Old Feb 12, 2008 | 07:12 AM
Rockledge's Avatar
Rockledge
Check your Owners Manual, it has the exact information you are looking for.
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Feb 16, 2008 | 02:58 AM
khadma's Avatar
khadma
Carpenter Local 745
Insert your key partially in the switch and turn to the off position. It will work if you do it properly - simple, even a caveman can do it.
jdhudall
1997 - 2003 F150
Dec 2, 2011 08:39 AM
CptSD
Jun 29, 2011 10:07 PM
00GT
May 11, 2011 10:46 AM
spork40
1997 - 2003 F150
Feb 18, 2010 05:32 PM
TonyPoss
May 28, 2007 01:42 PM
