Sponsored by: Auxito
air bag light
Old Jan 21, 2010 | 10:16 AM
spork40's Avatar
spork40
air bag light
i have a 2002 f150 and irecently removed my instrument cluster because at the time i wanted to remove my radio. i forgot to dissconnect the battery and once it put it all back together my airbag light by my spedo blinks and then stays on. also the key switch to turn the passenger bag on and off does nto respond, the light will not turn on. what can i do to fix it? what could i have bumped when i took the panel off?
Old Jan 21, 2010 | 08:15 PM
54FordF1shortstep's Avatar
54FordF1shortstep
Check all your connections around the steering column and make sure nothing is unplugged. Usually when the light blinks it means the airbag is completely disabled which leads me to believe you have lost a connection somewhere.
Old Jan 21, 2010 | 10:19 PM
fordtech08's Avatar
fordtech08
is your switch plugged in?
Old Jan 26, 2010 | 12:32 PM
spork40's Avatar
spork40
all plugs seem to be connected, any other ideas?
Old Jan 26, 2010 | 12:43 PM
fordtech08's Avatar
fordtech08
disconnect the light for airbag off( the light above the radio) then reconnect it
Old Feb 18, 2010 | 09:40 AM
spork40's Avatar
spork40
i tried unplugging the sensor and plugging it back in, witht the battery connected and with it disconnected but not luck. any other ideas? i really do not get it.
Old Feb 18, 2010 | 09:45 AM
fordtech08's Avatar
fordtech08
looks like your at the point where someone needs to pull airbag codes for you
Old Feb 18, 2010 | 05:32 PM
projectSHO89's Avatar
projectSHO89
Count the flashes to get the two digit flash code. You'll likely get an LFC of 52 or 27.
jdhudall
1997 - 2003 F150
Dec 2, 2011 08:39 AM
robs01f250
Feb 17, 2009 10:15 AM
alduane
1983 - 2012 Ranger & B-Series
Nov 2, 2008 04:44 PM
mainecorrado
Sep 20, 2005 09:12 PM
sgarcia
1997 - 2003 F150
Aug 19, 2004 10:09 PM
