air bag light
Old May 7, 2011 | 08:32 PM
00GT's Avatar
00GT
air bag light
98' ranger air bag light flashes and stays on. I think I know the issue. The keyed air bag off switch. When you turn it to the off position the off light does not come on. So I took it apart and the bulb is burned out. Would this cause the dash light to come on? Also the light is sodderd in........
Old May 8, 2011 | 04:48 AM
Dan Robertson's Avatar
Dan Robertson
Yes it will. Count the number of flashes before the light stays on. It is giving you a code number. Ford wants you to replace the entire switch but if you (or someone that you know) can solder, you can replace the bulb. I just went through that same issue with my Dad's F-150.
Old May 8, 2011 | 11:26 AM
00GT's Avatar
00GT
Where do you get a bulb that small?
Old May 8, 2011 | 05:53 PM
Dan Robertson
We took the switch to a radio repair shop. The guy there had a bulb and soldered it in for us. It wasnt quite the right style but it did the trick. He charged us $4.00 and that included the price of the bulb.
Old May 9, 2011 | 05:48 AM
03 Maz B23's Avatar
03 Maz B23
Radio shack carries some 12 volt bulbs with leads you can solder in place to replace it. As long as you have a soldering iron and solder should be an easy repair.
Old May 9, 2011 | 08:34 AM
00GT's Avatar
00GT
Thanks! I'll run out there today and pick one up
Old May 11, 2011 | 06:50 AM
00GT's Avatar
00GT
Ok I got the bulb sodderd in but the air bag light is still on. It flashes 2 times pause then flashes 5 times. Do I have to disconnect the battery?
Old May 11, 2011 | 10:46 AM
03 Maz B23's Avatar
03 Maz B23
Ford
--Prior to 2005, most models utilized Flash Codes --the airbag light would flash a 2 digit code repeatedly before remaining lit continuously. (There are some Ford, Lincoln and Mercury models that DO NOT use flash codes at all). The airbag codes can be read by counting the flashes on the dash light (flash, flash, pause, flash, = a code 21 on the fault code chart). The system would clear itself once the fault was corrected. Subsequent to 2005, most models require a scan tool to read the codes, configure the controller and/or clear the light.
Scanners capable of reading and resetting codes: Maxdiag, Autel, OTC, Launch
rbbarron
Jun 12, 2014 11:37 AM
robs01f250
Feb 17, 2009 10:15 AM
Snailboat
Sep 9, 2006 07:38 PM
StevenA
16
Nov 17, 2003 07:07 AM
