year model
Old Feb 10, 2008 | 07:00 AM
tanman722001's Avatar
tanman722001
year model
How can i find out what year my motor is?I just got the motor.The guy said it is a 390 with factory 4 bbl heads and intake.He also said it only has 2100 miles on it since it was total rebuilt.But he didnt know the year of the motor.Thanks Tony
Old Feb 10, 2008 | 07:28 AM
Freightrain's Avatar
Freightrain
Look at heads, in the center between exhaust ports. Should have a Cxxx that would determine the head year(and what they actually are).
Old Feb 10, 2008 | 09:07 AM
tanman722001
It looks like it is D2TEAA.So what does this mean?
Old Feb 10, 2008 | 10:24 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
D2 heads were model year 72 and up heads.
Old Feb 10, 2008 | 10:29 AM
baddad457's Avatar
baddad457
Date code on the block behind the oil filter adapter will tell the exact year the block was cast. The head date code is inside the valve cover. And 2 bbl & 4bbl---no difference in the heads. That sounded like sales hype to get you to cough up more cash.
Old Feb 10, 2008 | 10:42 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Actually block date code is below the oil filter adapter not behind. Head date code is between the center 2 valve springs under the VC's. Just to clear that a bit as it sounded like the head date code was in the valve covers!! LOL
Old Feb 10, 2008 | 10:44 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
You can also check the stroke easy enough to verify 360 vs 390. Other than that if she runs good enjoy the truck.
Old Feb 10, 2008 | 11:01 AM
tanman722001
Ok this is what i found,The number on the heads are 3M11 and 4A16 and the block number below the oil filter adaptor is 4M82.So what does this say?And does the head have the same number?
Old Feb 10, 2008 | 11:31 AM
baddad457's Avatar
baddad457
Heads would be December 11 1973 (3M11) and January 16 1974 (4A16) If the block is a 70's casting then it's a year later casting December 1974, the "82" doesn't jive for the day of the month, maybe it should be "22" ?
Old Feb 10, 2008 | 11:32 AM
baddad457's Avatar
baddad457
Old Feb 10, 2008 | 11:36 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
The heads 3M11 is 73/Dec/11th and 4A16 is 74/Jan/16th. Providing the block is a D3 block it has a 74/Dec/?? date code. That 82 is not correct. The last one or two numbers is the day of the month it was cast. I'd say the heads are possibly original to each other being a little over a month apart. The block is a year off tho. So either the block or heads are original. You'd have to find the build date of your truck to see which is closer to the date codes you have. Typical time frames are 30-90 days apart for engine date codes from the build date of the truck.
Old Feb 10, 2008 | 11:38 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
yep ya type faster than I do!!! LOL
Old Feb 10, 2008 | 11:58 AM
tanman722001
Thanks guys.I bought the motor.Going to put it my 73 F100 4X4.I will check the stroke out and let you know what i find.Thanks Tony
Old Feb 10, 2008 | 12:01 PM
baddad457's Avatar
baddad457
Great minds think alike.................... And have nothing better to do on Sunday morning too................
Jmatthews
51
Sep 30, 2014 06:41 PM
excavator
Mar 10, 2014 07:04 PM
foobeca
Jun 1, 2013 11:50 PM
smash fascism
Aug 19, 2012 08:22 AM
