Where to mount CB
Old Feb 8, 2008 | 03:06 PM
NigroCharlie's Avatar
NigroCharlie
Where to mount CB
I have a 1994 ford ranger standard cab and I cant seem to find a good place to mount my CB radio. I tried puting it under the dash but it gets in the way of the shifter. So what have you guys done? I really dont want to put it on top of the dash.
Thanks
Old Feb 8, 2008 | 03:13 PM
aquanaut20's Avatar
aquanaut20
Mount it fore and aft on the side of the Tranny hump
Old Feb 8, 2008 | 04:08 PM
Hank85713's Avatar
Hank85713
depends on which CB. I have an LTD25 by cobra its in the middle of the trans hump (94 SC) I just had to move it more into the lowere heater duct. Only problem I have occasionally is when I open the ahtray to put the phone charger in and then when I close I have to push the front of the CB down to clear the tray. The dash is all plastic make sure you drill into the lower steel support to hold the radio up.
Old Feb 8, 2008 | 04:21 PM
79-400-POWER's Avatar
79-400-POWER
got any pics of cbs in 03 rangers?
Old Feb 8, 2008 | 05:16 PM
dkf's Avatar
dkf
Heres a pic from the gallery of billybob69 with his CB monted in his SD.
This is how I'm going to mount my CB when I get around to it. The SD and Ranger use the same size radios. I think it is a great setup, but you need another radio and a Double Din install kit to make it work.
Old Feb 8, 2008 | 05:55 PM
RangerJustin's Avatar
RangerJustin
here is my 04, mounted it the same in my 05, wont work if you have a stick though. have seen people mount it on the headliner between the visors.
EDIT: Have also seen people mount it above where mine was, so that could work if you had a stick
Old Feb 8, 2008 | 10:43 PM
RangerPilot's Avatar
RangerPilot
In my '94 I put it below the driver's seat, mounted the handheld part to the center console. Worked fine, just reach down and turn it on.
Old Feb 9, 2008 | 09:24 AM
sfcwoodret's Avatar
sfcwoodret
Mount it overhead next to the visor and run the wire down the door frame.
Old Feb 9, 2008 | 10:36 AM
pgw85706's Avatar
pgw85706
Is the back wall of the cabin an option?
Old Feb 9, 2008 | 10:52 AM
JaysRanger's Avatar
JaysRanger
i have a 98 ford ranger and at first i mounted it right in the middle on the back but the only thing about that is u have to turn around to check it and everything im always messing with mine but i just moved it last night i took the drive side visor clip that hold its up lil plastic piece and i use the screw and mounted it to the top of the cab u aint got to drill no holes are anything and put a mic clip on the side and your done and u wont see no wires give me a sec and ill go get a pic of it and post it on here for u can see i might try and make it fit like that one pic right under the cd player that was cool never thought of putting it there
Old Feb 9, 2008 | 11:05 AM
JaysRanger's Avatar
JaysRanger
well i dont knwo how to put pics on here are i would show u
Old Feb 9, 2008 | 12:25 PM
dkf's Avatar
dkf
Load pics into your Gallery off your hard drive.
Copy and paste the pics from your gallery to the reply to the thread.
Old Feb 9, 2008 | 06:23 PM
fordboy_52's Avatar
fordboy_52
here is where i put mine. It took a hell of alot of modifications and a good dremill. i wouldnt suggest it, because there isnt as much room in the dash as a full size.
Matt
chaser1602
Feb 25, 2014 03:29 PM
illini5190
Dec 17, 2010 12:53 PM
zxsmyers
1997 - 2003 F150
Jul 2, 2009 06:22 AM
Doodaah
Aug 30, 2005 06:51 AM
hang10
Jul 8, 2004 05:30 PM
