Sponsored by: Auxito
shifter needle
Old Mar 9, 2008 | 10:51 PM
tim.moman's Avatar
tim.moman
Finally got into my dash today. Weather has been just a little to cold to mess with it til today. Turns out the little white piece is broken. Is this a dealer item only and would they have it in stock?
Old Mar 10, 2008 | 07:20 AM
Spotty's Avatar
Spotty
Unhappy
You can get at it from underneath. I think just 1 screw holds it on. Just take it apart, take the black threaded adjuster out, and super glue the white piece back together. No real force on it, I glued mine years ago, still good. If I recall, strictly a dealer item. I broke mine taking out the cluster,(for the first time), to change cluster bulbs. I didn't know about the cable till I broke the adjuster
Good Luck...
Spotty
Old Mar 10, 2008 | 03:06 PM
Bobby82490's Avatar
Bobby82490
yeah i would just glue or jb weld the white piece together, there is hardly any pressure on it.
Old Mar 14, 2008 | 11:10 AM
jimjudy2's Avatar
jimjudy2
Great Advice: shifter needle
My white thumbwheel was broken...cause of my shifter needle to be out of place and awkward shifting into park and reverse (as mentioned in another post, when I was parallel parking, I probably shifted into reverse or drive too quickly...and that started all my problems).
I was hesitant to believe the darn wheel could cause the shifter needle to be off and shifting into park and reverse to be so awkward feeling. However, it was and through the advice of this forum, I located the thumbwheel, saw that it was broken and used a plastic tie to get the thumbwheel back in place. Only concern I have now is that the tie doesn't rub against the nylon-type cable. I'm going to apply some super glue or epoxy to make sure the plastic tie doesn't rub against the cable.
And, the more I read the forum, the more I find I have the exact same problems...next one I may takle is my digital odometer...goes on and off and there's a good thread on how to fix that.
Again, thanks for the great advice!
Old Mar 15, 2008 | 09:01 AM
superdutymj's Avatar
superdutymj
You'll find that most of us on this forum share alot of the same problems. '97-'03 F150s all seem to have similar little quirks that most of us have experienced and can help the ones who's truck is acting up. Thanks for joining us on FTE, and don't hesitate to share any problems or concerns relating to your F150(s)!
thomc
Jan 9, 2013 04:28 PM
Gordon Grooms
Electrical Systems/Wiring
Dec 4, 2012 05:40 PM
nolan62
45
Jul 6, 2011 03:55 PM
Jspafford
1983 - 2012 Ranger & B-Series
Dec 7, 2008 11:02 AM
paulbunyan22041
May 24, 2004 06:25 AM
