Gauge Indicator Needles
Old Dec 3, 2012 | 06:59 PM
Gordon Grooms's Avatar
Gordon Grooms
I cleaned dust from instrument cluster faceplate & inadvertently moved the gauge indicator needles on my 96 F150-302. Got all put back together, started the engine & now needles are pegged to the left on oil pressure, water temp & alternator gauges. Gas gauge & speedometer work OK. Forgot to disconnect the neg battery cable. Will the gauges relearn settings after driving X miles?
Old Dec 4, 2012 | 11:42 AM
Franklin2's Avatar
Franklin2
Your 96 as far as I know has regular old-time gauges, nothing with a brain that controls them. I would suspect a connection is loose on the back of the cluster. Make sure the large connectors are in all the way and straight.
Old Dec 4, 2012 | 05:40 PM
Gordon Grooms
Thanks much for the prompt response and I will go back & check the connector. The forum has saved my ___ many, many times.
three on the tree
Jan 15, 2019 04:08 PM
THartman
15
Feb 25, 2018 02:39 AM
Hawkmcgee
Aug 24, 2013 09:12 AM
jfarcas
Jul 14, 2007 09:33 AM
HillbillyHellcat
Mar 6, 2004 07:26 PM
