Shifting question
Old Feb 5, 2008 | 05:26 PM
WALJON's Avatar
WALJON
Shifting question
Hi is this normal? yesterday I had my battery cables off for about 3 hours and when I drove home the tranny shifted funny it went into od way too soon and wouldn,t shift down this morning on the way to work it shifted fine and ran good too
thanks
Old Feb 5, 2008 | 06:07 PM
tjbeggs's Avatar
tjbeggs
Yes that could very well be normal. The PSD doesn't have any "learning" ability but the E4OD does. So when you unhooked the batteries it reset it.
Old Feb 5, 2008 | 06:19 PM
Action4478's Avatar
Action4478
Drive cycles .....
Old Feb 5, 2008 | 06:36 PM
WALJON's Avatar
WALJON
Thank you!
Old Feb 5, 2008 | 09:06 PM
WALJON's Avatar
WALJON
[QUOTE=tjbeggs]Yes that could very well be normal. The PSD doesn't have any "learning" ability
ok my truck was running awful before this as well and now it seems way better could all the screwing around I was doing with the ICP have given me the poor running problem? I since have soldered the wire on the sensor back to stock and it just seems now to be better after the batteries were unhooked?
Old Feb 5, 2008 | 09:12 PM
c00nhunterjoe's Avatar
c00nhunterjoe
that last part seems odd, as soon as you cycle the key it should reset everything, even if a code is stored
Old Feb 5, 2008 | 09:25 PM
WALJON's Avatar
WALJON
Yeah I don,t know ? I am trying to figure out why when I fart around with the ICP it seems to make the truck run crappy when I soldered the wire back it still ran crappy till last night after the batteries were unhooked for those few hours?
It now runs like it is supposed to?
Old Feb 5, 2008 | 09:51 PM
MADVAN's Avatar
MADVAN
Its normal. Also seems to happen more if you have a chip.
Nothing to worry about.
Statement is on the shift thing.
Bill
Old Feb 5, 2008 | 09:55 PM
WALJON's Avatar
WALJON
Thanks Bill I also noticed this after installing a super chips tuner
talking about the shifting thing
Old Feb 5, 2008 | 09:56 PM
WALJON's Avatar
WALJON
I meant un installing sorry
Old Feb 5, 2008 | 10:01 PM
MADVAN's Avatar
MADVAN
Got ya.
Even with the batts connected a change in the flash or a chip will sometimes do the same. It goes thru a little freekyness then all is good. Alot of time, the TC will haunt during this set time.
Your good to go.
Bill
Old Feb 6, 2008 | 04:22 PM
mohare7's Avatar
mohare7
Hey - I had the PCM in my 96 flashed 3 weeks ago, and it still shifts into OD at about 35 mph. You think disconecting the batteriries would work?
Old Feb 6, 2008 | 08:26 PM
WALJON's Avatar
WALJON
flashed with what? do you mean when put back to stock?
Old Feb 6, 2008 | 10:43 PM
islander's Avatar
islander
have not worked on psd much only had mine for two years. wrenched lots of gas pots and found that computer will put truck in safe mode for one reason or another. long story short is it will run just not very good. take neg. cable off have a beer put it back on computer re boots and away ya go.
Old Feb 7, 2008 | 08:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first trans behind a diesel in a Ford that had ANY learning ability was the TorqShift. The E4OD never had any learning ability in any application.
The first Ford trans ANYWHERE with learning ability was in 1999, and it wasn't in the trucks.
