Well tonight my overdrive light started flashing and it would'nt shift out of like 5th gear or whatever it was stuck in.... I was in the hills in some deep snow when this happened and I was running the truck pretty hard, I was keeping an eye on the EGTs the whole time since I have an EGT gauge....... But im not sure exactly what happend here with this tranny....... any ideas?? Thanks for any help!
i would pull the VSS off of the rear end..you may have packed it with snow and dirt...clean it and dry it out good..put it back in and try again..if that does not work..scan for codes....
Pull the pan and check to see if the filter has came loose. Also check to see if the dent is big enough to restrict the flow into the filter, The codes point towards bad problems but we all hope not. Coast clutch out, overheat, shift errors, etc. Do you have aftermarket gauges? Check out the filter and pan and tell us what you find. Maybe just needs new fluid but it doesn't sound like it.
Sorry, Joe
I just had a filter and fluid flush done, I smelled the fluid today and it did kinda smell burnt..... I dont yet have a trans temp gauge but I will soon. I really dont think the dent is big enough to have hit anything...... I said its stuck in 5th gear or whatever, but im guessing its just stuck in overdrive. I have to put it in 1st or 2nd to start out.
Did I toast this thing or could it be something simple?
Well guys I changed the VSS and it didnt do anything, although the old one was very dirty.
As you discovered changing parts without knowing the codes is often a waste of money.
Originally Posted by a-rod
I pulled 8 codes, all transmission related. I hope this isnt bad.....
po733
po750
po755
po743
p1754
p1728
p1747
p1783
That looks like the trans is electrically disconnected. That will also cause it to stay in fourth gear (overdrive) all the time.
Check the wiring harness connector on the passenger's side of the trans. Is it damaged or disconnected? Is there water or oil inside the connector? Are any fuses blown? Maybe the wiring harness to the connector is damaged. It could also be the wiring harness inside the pan. It could have been damaged when the pan was dented.
Thank you Mark! I was thinking maybe something electical as well, but im no transmission expert! Im gonna tear into later when I get off work. Ill let ya know what I find.
ok I pulled the pan and realized the dent was bad enough that it hit the filter and slightly cracked the rear corner of it. I couldnt find any blown fuses or anything wrong with the harness, but im gonna check it closer yet. Could the cracked filter have caused all this?? Im gonna go see if I can get one downtown. Thanks
