351c headers on a 400m
Old Jan 30, 2008 | 11:26 PM
OldBlue68's Avatar
OldBlue68
ive heard that you can use headers from a 351c on a 400m..was just wondering if this is true? and if so could i fit any header from a 351c then?
Old Jan 31, 2008 | 05:16 AM
garypettengill's Avatar
garypettengill
If the headers are from a 351C 2V engine then yes, they will fit the head exhaust bolt pattern of the 351M/400 engine. Otherwise they will leak unless an adapter plate is used to prevent leakage with the bigger 4V ports. Sanderson headers in Calif. makes a set of shorty headers for the 351C 4V heads and sells them with the needed adapter. Been running a set for a couple of years now.
Old Jan 31, 2008 | 11:41 AM
mark a.'s Avatar
mark a.
A full length set of headers may sit too high in the chassis, due to the blocks different deck heights.
Old Jan 31, 2008 | 05:15 PM
trinogt's Avatar
trinogt
Since trucks never came with a 351C, you might have a hard time getting any 351C headers to fit a truck... Might get lucky with the shorties though...
If you are buying them new, buy for 351M/400 for the year your truck is. I have a set made for the year of my truck, but never put them on!
Old Feb 13, 2008 | 08:28 PM
ladiabla74's Avatar
ladiabla74
In my 74, I have a 351c with full lenght headers ordered for a 73 msutang and they have the clearance on the chasi and floorpan. Problem was the tranny crossmember. Had to cut and weld u shaped pass throughs since the headers end up right at the midle of the crossmember. That worked well.
My 78 on the other hand has a 351m with long headers and they go right below the crossmember thus no cutting necessary.
BigCountry1978
Jul 16, 2016 01:05 AM
2matsha
1978 - 1996 Big Bronco
Dec 11, 2015 05:37 PM
351Cleveland C4
Dec 28, 2014 09:56 PM
f250custom78
Jan 16, 2013 07:22 PM
havi
Feb 17, 2012 07:18 PM
