Axle seals
Old Jan 30, 2008 | 03:21 PM
Kerrie's Avatar
Kerrie
Axle seals
My 2000 Expy needs new axle seals for inspection. Any tips/suggestions on doing this job? Any special tools needed? Any help would be greatly appreciated!
Old Jan 31, 2008 | 01:19 PM
DMB's Avatar
DMB
Not too bad of a job. The Haynes manual has a good, accurate section on how to do this. Basically you jack the rear up, drain the rear end by removing the diff cover, and remove the pinion shaft. Remove the wheels and brake rotors to access the axles. Push the axles in, then remove the locking "c" clips on the end of the axles inside the diff. The axles then slide right out, and you can use the end to pry the old seal out. Install new seals, replace axles, and button it back up. When you jack the rear up, make sure you've got sufficient (4') side clearance so you can get the axles out - don't want it up in the air only to find out the sidewall of the garage is in the way.
Replace and locktite the pinion shaft lock bolt. Don't forget to add friction modifier if required. Also a good time to make sure the axle vent tube is clear. A clogged vent tube lets pressure build up inside the axle, which may contribute to blown axle/pinion seals. Also a good time to inspect and/or replace the pinion seal.
Only "special" tools needed are a torque wrench and an appropriate size socket or other implement to drive the new seals home.
Old Jan 31, 2008 | 02:32 PM
Kerrie's Avatar
Kerrie
Doesn't sound too bad...I'm gonna buy the manual to have handy. I'm planning on a full day, cause you know it's never really simple...something always goes wrong or you always find something else...ha ha
Thanks for the reply!!
Old Jan 31, 2008 | 03:08 PM
gregj's Avatar
gregj
Also a pump to replace the lube is handy.
Old Jan 31, 2008 | 03:38 PM
DMB's Avatar
DMB
A pump helps, I just used a screw-on hose on the lube bottles - plenty of room above the axle to tip one upside down.
One other thought - If your seals are leaking, you probably have axle lube all over your parking brake pads/assembly, and maybe the main brakes. At a minimum, you should plan on replacing the parking brake pads, as they're likely well oiled. May find the parking brake linkage binding as well; a soak in PB Blaster should free it up. Anti-seize moving parts and mating surfaces (acid brush works great) and you won't have any problems if you ever have to disassemble in the future. Also, you will probably have to back off the parking brake adjusters in order to get the brake disc/drum assembly off.
Black RTV the diff cover and evenly torque, you don't need a gasket. Let it cure in place as long as you can (24hrs) before driving to help prevent leaks.
Old Jan 31, 2008 | 04:45 PM
Kerrie's Avatar
Kerrie
Awesome advice, thanks!
Old Feb 3, 2008 | 01:22 AM
98expeditionXLT's Avatar
98expeditionXLT
Go to West Marine for a pump kit with hose that replaces cap on quart size containers of gear oil for the lower ends of outboards.
Old Feb 16, 2008 | 01:04 PM
bentonsexpy's Avatar
bentonsexpy
I just took my '04 in for the 60,000 mile service and they said the rear pinion seal was leaking and needed replacing, luckily they worked it in and it didn't cost that much with the service. I might have tried replacing it by myself with my '97 but hate messing with the newer one.
pacrewchief
Jun 9, 2012 09:12 AM
A/Ox4
Sep 28, 2011 01:38 AM
pjd822
Jul 30, 2010 04:41 PM
sdeforest
1997 - 2003 F150
Jan 17, 2007 06:28 PM
VirginiaWiFinder
May 30, 2005 11:54 AM
