Rear axle seal
Old 07-30-2010, 02:51 PM
pjd822
pjd822 is offline
pjd822 is starting off with a positive reputation.
Rear axle seal
The rear axle seal on my '59 F100 needs to be replaced. Is it an easy repair and are any special tools needed?
Old 07-30-2010, 02:57 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
I did the seals on my '59 F250,they didn't require any special tool.You have a 9" differential probably,while I have a Dana 60,so I'm not 100% sure.If you don't already have one,buy a factory shop manual,that will tell the tale.
Old 07-30-2010, 04:08 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
No real special tools are required. It is a straight forward repair. (assuming a 9" Ford axle) Pull the axle shaft and the seal is right there at the end of the housing tube. Remove old seal, replace with new, reassemble everything. The thing you'll want to check, though, is the axle bearing while you have the shaft out. Many times, the seal fails as a result of a bearing failure, allowing the axle shaft to move around slightly.
Old 07-30-2010, 04:41 PM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.BlueOvalRage has a great reputation on FTE.
When you get the axle pulled out, here's a neat tip for getting the seal out. That is sometimes the hardest part. The seal sits down in the tube a bit and is tough to get a normal seal puller into. Take a scratch awl or a long nail and punch two holes through the metal part of the seal on opposite sides. Thread a couple of 3" drywall screws into the holes and then you can alternate back and forth with a claw hammer to pull it right out. Works every time!
pacrewchief
06-09-2012 09:12 AM
mikecwik
04-26-2010 07:23 AM
little_mule
11-04-2009 07:33 PM
mdrose64
1997-2006 Expedition & Navigator
02-14-2007 04:40 PM
mebush
12-01-2005 10:50 PM
Quick Reply: Rear axle seal
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
