P0705 Code, any ideas?
Old Feb 14, 2008 | 04:04 PM
Greenscobie86's Avatar
Greenscobie86
Hey all,
I went through some deep puddles in my 98 after the first big snow/rainstorm we had here in NYC, and about 30 miles later bang! A CEL.
After a trip to Autozone here is my problem,
P0705-Transmission range sensor malfunction
My question is, is this definitely a faulty sensor or could it be a short due to some water getting in there? Just for reference one of my HID headlights started to flicker last night as well, maybe I wet alot of stuff while fording some of the deeper puddles. What do you guys say?
Thanks in advance.
Old Feb 14, 2008 | 07:56 PM
Jimmygunz3's Avatar
Jimmygunz3
I live in NYC and this happened to my 99 eb in the snowstorm. I reset the computer and today I drove to NJ and back and the CEL hasnt come back on. I think it probably was the water causing a short. Did you try to clear the codes? I posted this the night it happened and someone sent me this link . hopefully it will help.....
https://www.ford-trucks.com/forums/6...tml#post5239268
Old Feb 15, 2008 | 05:25 PM
madsonp's Avatar
madsonp
His link doesn't work. Try this one. https://www.ford-trucks.com/forums/6...ml#post5239268
Old Feb 16, 2008 | 04:32 AM
Greenscobie86
Thanks for the links guys. So far I've reset the ECU and no code, knock on wood. I'm hoping this was due to the water as I stated before. Now I'm more educated on the problem, if it comes back on I'll try fiddling with the shift cables/sensor, if not I made it out easy.
Thank you for the help!
BTW: Jimmy looks like you're local. I'm on SI too. What a coincidence! We got the same code at the same time, living in the same area! SI is small enough, maybe I've seen your truck around?
Old Feb 16, 2008 | 10:55 AM
tommyleea's Avatar
tommyleea
Maybe Arlin Spector can figure it out.
Old Feb 16, 2008 | 02:56 PM
Jimmygunz3's Avatar
Jimmygunz3
I am sure we probably have seen each other in passing, but yea its too funny that the same thing happened to ours trucks around the same time
RoyalFord
1997 - 2003 F150
28
Jan 2, 2024 05:14 AM
Sam zbond
Apr 24, 2016 02:56 PM
BogginDave
Mar 30, 2016 04:09 PM
Nunnerym
1997 - 2003 F150
Sep 8, 2015 08:12 PM
Orezona
Jun 27, 2009 10:34 PM
