2002 Ford Explorer XLT-auto 4WD
Old Jan 28, 2008 | 11:52 PM
RBXcell2's Avatar
RBXcell2
Smile 2002 Ford Explorer XLT-auto 4WD
I just bought my explorer and was wondering if anybody knew about the Auto 4WD. How do you know if it is on? Is there a light telling you it is on. There certainly is a button to press to turn it on. 4X4 High and low there is a light telling you it is on. 4X4 auto I don't know if it is on or off. Is my light broken that tells you this, or is there no light. How are you suppose to keep track when it is on or off. Thanks for all your help
Old Jan 29, 2008 | 12:02 AM
aquanaut20's Avatar
aquanaut20
You dont need to know that is why it is labeled "AUTO".
but if you want to test it go to a sandy surface, turn the front wheels at a slight angle and step on it, all 4 wheels should show sign of powering up.
Old Jan 29, 2008 | 12:04 AM
khadma's Avatar
khadma
Carpenter Local 745
Here's a thread I started.
https://www.ford-trucks.com/forums/6...-explorer.html
It is always on.
Kick in when it senses slip, just like a giant LS rear end.
Old Jan 29, 2008 | 10:37 AM
RBXcell2's Avatar
RBXcell2
Smile Thanks for the help
Thanks for the help. Why does it have a button you can push if it is always on?
Old Jan 29, 2008 | 11:15 AM
antony25's Avatar
antony25
You press that button to take it out of 4 hi or 4 low.
Old Jul 3, 2008 | 02:28 PM
rpm5099's Avatar
rpm5099
I have a question to this older post - I have an 02 explorer V8 with the auto 4wd function. Is this vehicle equipped with auto locking hubs on the front, or are the hubs always engaged to teh differential and the front drive shaft? It seems that this would decrease gas mileage and cauase additional wear, but I dont see how else the auto4wd could engage in a fraction of a second.
Follow up question - I'm replacing the gear oil in the rear diff, do I need to do the front since the front hubs always seem to be "locked" to the differential? Thanks.
Old Jul 6, 2008 | 06:50 PM
johnf350diesel's Avatar
johnf350diesel
they are always engaged thats how it kicks in so fast. its incredible how quick the front wheels get power. i personally dont like having auto but now my truck isnt like that
Old Jul 7, 2008 | 08:40 AM
rpm5099's Avatar
rpm5099
So I assume that means I need to change the front diff oil at the same time...
MizzouGuy
Oct 21, 2011 05:33 AM
nixvet2000
1978 - 1996 Big Bronco
May 20, 2011 12:31 AM
MCDT
Feb 7, 2008 09:19 PM
97X-PLODER
Feb 19, 2006 12:09 AM
Quackhead94ranger
1983 - 2012 Ranger & B-Series
Mar 22, 2004 12:54 AM
