Air filter diagram
Old Jan 28, 2008 | 06:28 PM
antunez13's Avatar
antunez13
Air filter diagram
Can someone please draw diagram or picture of the hoses that hook up to the air filter assembly my father replaced the stock with an aftermarkt edlebrock so it dosent let the hot air in on cold mornings just all cold air
Old Jan 28, 2008 | 07:30 PM
Harte3's Avatar
Harte3
Obtain a repair manual like "Chiltons" available at most auto parts houses.
Old Jan 29, 2008 | 06:46 PM
antunez13's Avatar
antunez13
i have one
dosnt realy tell how it all hooks up i just want to get mine back to stock
Old Jan 30, 2008 | 12:14 AM
fmc400's Avatar
fmc400
MSEE
On the stock air cleaner housing, is a bimetallic temperature switch, with two ports. One of those ports (either one) will go to manifold vacuum. Anywhere you can find it on the intake manifold. The other port of that temperature switch goes to a little round thing on the snorkel of the air cleaner, called a "vacuum motor."
That will get you the warm-air setup back. You may also have a PCV hose going to a breather element in the air cleaner, down to the valve cover.
Old Jan 30, 2008 | 07:00 PM
antunez13's Avatar
antunez13
Thanks alot so does the bimetallic tempture go bad?
What is the little green and white round thing between bimetal temp and the vacume motor called
and were does the choke pulloff hook seems like it might have been teed off to the bi temp switch.
Old Jan 30, 2008 | 07:06 PM
fmc400's Avatar
fmc400
MSEE
Bimetallic temperature switch goes bad after a while. Choke pulloff gets manifold vacuum 100% of the time; no temperature switch there. If this is the stock Carter 1 barrel then you will either have a choke pulloff piston internal to the carb and no pulloff diaphragm. If you have an external pulloff diaphragm there should be a manifold vacuum source on the carb. If not, hook it to manifold vacuum.
Old Jan 30, 2008 | 07:15 PM
antunez13's Avatar
antunez13
Old Jan 30, 2008 | 09:16 PM
fmc400's Avatar
fmc400
MSEE
Sorry, I must have missed that. That's called a check valve. It lets vacuum go one way but not the other. The reason this is there is because as you accelerate, your manifold vacuum goes down. If there was no check valve in the path, the vacuum motor would lose the vacuum signal and would let the door in the air cleaner snorkel open back up at cold under-hood temperatures. The check valve keeps the vacuum that is holding the vacuum motor open from propogating back to the intake manifold. That way, once the door is shut it stays shut until the temperature rises, regardless of throttle position.
Old Jan 31, 2008 | 06:04 PM
antunez13's Avatar
antunez13
were can i buy one of these check valves, i cant seem to find one online, thats the only part i missing
Old Jan 31, 2008 | 09:59 PM
antunez13's Avatar
antunez13
is that green and white valve cald the cold weather modulator and were can i find one.
Old Feb 4, 2008 | 01:48 PM
robert l staecker's Avatar
robert l staecker
i have a f-150 2002 i need a diagram of the vacume hoses i cannot find them any where. bob
427ford
Jun 19, 2015 10:59 AM
brkncly
6.4L Power Stroke Diesel
Apr 15, 2015 07:53 PM
new7.3owner
Jun 24, 2014 06:34 PM
trucker01
16
May 10, 2014 09:23 PM
payner22
Apr 25, 2005 10:47 AM
