is this engine correct
Old Jan 26, 2008 | 11:28 AM
camaroneil's Avatar
camaroneil
just wondering if it still has the correct engine in it,
according to the vin (F10JH364385) it should have a 223 in it,
the engine number is EBP-6015-E
i think the date stamp off the engine is 48 E
it has three on the floor at the moment but this was obviously fitted later as the hole in the floor for the shifter is terrible and it has had the column shift lever cut off,
on the vin plate under trans it ha the letter A, am i right in assuming that means auto ?
also, axle states 13, does that indicate the ratio?
thanks,
neil
Old Jan 26, 2008 | 12:25 PM
camaroneil's Avatar
camaroneil
just found the axle code and it transpires to be a 4.11 ratio,
WBG-L
Old Jan 26, 2008 | 06:46 PM
garbz2's Avatar
garbz2
Is the engine an I6? with the intake on the drivers side it is a 223.
Garbz
Old Jan 27, 2008 | 04:02 AM
camaroneil's Avatar
camaroneil
you're correct, I-6 with intake on drivers side,
many thanks,
neil
Old Jan 27, 2008 | 02:44 PM
Col Flashman's Avatar
Col Flashman
Well the only other I-6 it could be, is the Big Brother of the 223, the 262 I-6, so there you go.
Old Jan 29, 2008 | 04:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
according to the vin (F10JH364385)...on the vin plate under trans it has the letter A...am i right in assuming that means auto ? NO
F10 = F100 2WD
J = 223 1V / I-6
H = Detroit Truck Assembly Plant
364385 = Assembled December 1962 (as a 1963 model)
Transmission Code: A = Ford 3 Speed Manual All Syncromesh Transmission
Old Jan 29, 2008 | 12:40 PM
camaroneil's Avatar
camaroneil
mmmm,
thats interesting that it came with a 3 speed manual,
i wonder why it's been hacked to make it a floor shift,
it may have a different gearbox in it,
any ideas what model gearbox should be in it???
if anyone has pics of the linkage for a 3 on the tree please share them,
neil
Old Jan 29, 2008 | 12:50 PM
NumberDummy
mmmm,
neil
I doubt the 3 speed gearbox has been changed.
Here's what usually happens...
Either the shift coller breaks (common), and a previous owner couldn't find one (why I don't know), or the shift lever hangs up between 1st/2nd gear...a common problem on these trucks. All that's needed to fix this hang issue are two bushings and insulators, which fit into the two manual control levers, bottom of the steering column under the hood.
The parts are readily available for these two issues from NAPA, but some ppl are clueless, and convert to a floor shifter, doing the usual hash job in the process.
Pictures: 1957/63 Ford Truck Parts Catalog is available on a CD from hipoparts.com / also on ebay.
For less than 25 bucks, you can have illustrations of EVERY part your truck has. The parts catalog can also be used as an assembly manual because the 1000's of illustrations basically show how things are put together/come apart.
You also get ALL the part numbers.
Old Jan 29, 2008 | 02:27 PM
camaroneil's Avatar
camaroneil
many thanks for that,
i need to find someone over your side of the pond that is willing to let me get the bits sent to them - or pick them up for me, then they can forward them to me,
i would obviously pay them in advance,
i'll try and have a good look at the linkages in the next day or so,
thanks again,
neil
Old Jan 29, 2008 | 02:56 PM
NumberDummy
thanks again,
neil
Didn't notice your UK address, but shipping parts there shouldn't be a problem.
The pound sterling is at this time...the highest it's been in years as to the US dollar...why I'm staying on this side of the pond this year.
Last time I looked, it was 56 pence to one US dollar.
There's no VAT in the US.
On this page there are a list of FTE sponsors, you can contact them for shipping info:
New and reproduction parts: BLUE OVAL TRUCK PARTS / MAR-K / NATIONAL PARTS DEPOT / AUTO-KRAFTERS / MAC'S ANTIQUE AUTO PARTS. All have online catalogs.
GREEN SALES sells new old stock (NOS) Ford obsolete parts.
Old Jan 30, 2008 | 10:13 AM
camaroneil's Avatar
camaroneil
thanks for the links, i'll give them a try,
would be nice to get the gears back on the tree,
it's no problems getting bits sent here, it's just we get stung with import duty/tax and then VAT on top of the lot,
it usually doubles the price of bits,
the car failed it's MOT (inspection) on front brake balance so looks like i'm gonna have to strip the brakes and give them the once over,
oh joy,
thanks,
neil
Sep 9, 2016 07:39 AM
merwin68
Large Truck
Jul 26, 2016 06:59 PM
vinnyd62
May 3, 2015 01:51 PM
gcooper8
1983 - 2012 Ranger & B-Series
Jun 21, 2009 11:16 PM
eficat
18
Apr 19, 2009 09:36 PM
