Difference between 4.0 Vin E and Vin X
Old Jun 21, 2009 | 11:02 PM
gcooper8's Avatar
gcooper8
Greetings,
I have located a 2001 4.0L Explorer Vin E engine with 59k for cheap. Can I put that in my '97 Ranger that has a 4.0L Vin X that has 140k?
What are the differences? What would I have to change? Is it worth the hassle?
gcooper8
Old Jun 21, 2009 | 11:11 PM
Bear River's Avatar
Bear River
Former ******
The 2001 is an overheat cam(SOHC), while your '97 would be a pushrod overhead valve (OHV). Swapping the two would be far more complicated than you would think.
You would probably have to change most of the electronics, a few accessories, redo the exhaust, and probably need new motor mounts and a tuner to re-calibrate the computer, even if you use the ECU from the 2001, you need to calibrate it for your transmission and gear ratios.
Old Jun 21, 2009 | 11:16 PM
gcooper8's Avatar
gcooper8
Many thanks for the response. Sounds like too much trouble. Thanks again!
geo
PW01
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 22, 2017 12:34 PM
4.9
Sep 9, 2016 07:39 AM
Pxt808
Jan 22, 2016 08:06 AM
gcooper
Apr 14, 2006 09:18 PM
frankystarlight
24
Sep 17, 2005 10:48 AM
