aod trouble
Old Jan 24, 2008 | 07:06 PM
njtinman2's Avatar
njtinman2
aod trouble
ok here goes 89 f150 4x4 302 aod trans rebuilt the trans with tci kit and did the trans scat shift kit and now only have 1st and reverse any ideas
Old Jan 24, 2008 | 09:08 PM
njtinman2's Avatar
njtinman2
what no ideas?
Old Jan 24, 2008 | 09:53 PM
Conanski's Avatar
Conanski
So it worked before you put the kit or kits in? DO you have the TV cable attached to the throttle and properly adjusted? How much tranny fluid did you put in it?
Old Jan 24, 2008 | 11:14 PM
icrman's Avatar
icrman
So its a fresh rebuild and it doesn't work? Or it worked for awhile and now it doesn't?
It stopped working after the shift kit? We need more information.
If its just been rebuilt and doesn't work then some one goofed up. It could be lots of things, internal leak, linkage not adjusted right, something in valve body not put in correctly and on and on we go.
Old Jan 25, 2008 | 08:11 AM
njtinman2's Avatar
njtinman2
i think its in the valve body when i first drove it it had 4 gears then it went to just 1st i thinking its the valve body and i rebuilt it because the direct clutch pack burned up and did it by the book
Old Jan 25, 2008 | 09:14 AM
njtinman2's Avatar
njtinman2
and to add the tx cable is conected and adjusted lick the book says to
Old Jan 25, 2008 | 10:45 AM
ned37's Avatar
ned37
try these guys: http://www.network54.com/Forum/260730/ they speak aod . sounds like crap in one of the lines in the valvebody or the governor unit. make sure your tv line pressure is right.(33-39psi)
i'm guessing it freewheels after you rev it out in first?
Old Jan 25, 2008 | 09:25 PM
njtinman2's Avatar
njtinman2
yes it does freewheels but if you steap on it it stays in first
Old Jan 25, 2008 | 10:38 PM
ned37's Avatar
ned37
what is your tv pressure? did you disassemble and clean the governor unit on the tailshaft?
Old Jan 26, 2008 | 06:44 AM
njtinman2's Avatar
njtinman2
heve not checked pressure yet and yes cleaned governor
Old Jan 26, 2008 | 07:52 AM
njtinman2's Avatar
njtinman2
ok the more i read makes me ? tx cable adjustment lets hear how should i adjust it i think my book is bs it says to set it with valve lever at trans all the way back??????
Old Jan 26, 2008 | 09:28 AM
Conanski's Avatar
Conanski
You shouldn't have to touch the cable at the tranny. The proceedure I have seen is to pull the jacket of the cable back enough to take any slack out of the cable at the throttle connection, and lock it down. Slightly more preload than this will move shifts up in rpm, but you don't want any less preload than this.
Old Jan 26, 2008 | 10:08 AM
ned37's Avatar
ned37
make yourself a gage (a cheap oil pressure gage will do (0-100)) get a piece of hose, clamp it to the gage, run the hose to the middle plug found above the passenger side above the pan toward the rear. pull the fitting out and attach an 1/8 pipe fitting to the hose. put it in the open port. make a test spacer for the tv cable by taking a 10mm bolt about 2" long and cut off the threads. cut a notch in the cut end big enough to fit over the tv cable inner cable. using pliers, grab the metal tip that sticks slightly out of the front of the plastic attaching clip and pull it out of the sleeve far enough to slip the spacer over the cable which will hold it out a given distance.
warmup the trans to about 160*, read the pressure at idle. adjust the cable by popping up the retaining clip at the mounting bracket to get between 33-39 psi. (higher the pressure, the more positive the shift)
Old Jan 26, 2008 | 10:45 AM
winfordr's Avatar
winfordr
This is a picture of my TV cable on my '88 F150 5.0.
http://www.winfordr.com/FordTruckStuff/197a.jpg
I found that the easiest way to get the adjustment right was trial-and-error.
When the cable is properly adjusted, the trans will shift into OD at 37-40 mph on level ground - at normal cruise (not pulling or coasting). Checking the pressure may help determine if there are other problems, but if the only problem is the TV cable adjustment, this can save a lot of time and hassle. Just make an adjustment, take a short test drive - don't drive any further than necessary with it mal-adjusted. You may need to click on the picture to zoom in.
Old Jan 29, 2008 | 03:20 PM
njtinman2's Avatar
njtinman2
i droped the pan and took the valvebody a part i had the 2 releif valves in upsidedown but there was some glitter in fluid put vb back in still only 1st and rev can it be the vb has anyone used the tci trans scat kit and did it work
A73F100
Jan 14, 2014 07:50 PM
thunderbolt427
Nov 6, 2012 06:31 PM
76f250highboys
1978 - 1996 Big Bronco
Jan 10, 2011 08:37 PM
Rbomar
Sep 21, 2007 11:28 AM
Jason8705
Sep 10, 2004 12:11 PM
