Tranny problem
Old Jan 22, 2008 | 05:37 PM
heathrunkles's Avatar
heathrunkles
Tranny problem
Hey guys-going down the road today for work(about 30miles into the trip) the tranny jumpes out of OD into 3 but when I stepped on the pedal the rpms shot up but not the speed, like it was slipping. this was at 70mph- I let of the pedal and it shifted back into OD and was fine for ten miles or so before it did it again. only for 5-10 seconds at a time. Let it sit for two hours or so and it was fine for about 80 miles with weight on it, highway and city. No change in acceleration even when I mash the pedal-still shifts smooth and quick. just wondering if it sounds like the tc or something else. Thanks
Old Jan 22, 2008 | 06:36 PM
MADVAN's Avatar
MADVAN
Hit the OD cancle button and see if lamp lights.
Did the OD lamp flash?
Bill
Old Jan 22, 2008 | 07:04 PM
heathrunkles
The second time I did hit the od cancel. When i engaged it againit hesitated and then shifted back to OD. No flashing light
Old Jan 22, 2008 | 07:20 PM
MADVAN's Avatar
MADVAN
But does it light up when you cancel it?
Bill
Old Jan 22, 2008 | 07:23 PM
heathrunkles
yes it did light
Old Jan 22, 2008 | 07:44 PM
MADVAN's Avatar
MADVAN
CEL?
Bill
Old Jan 22, 2008 | 08:02 PM
heathrunkles
no. It only happened twice but the second time I was watching\feeling for it. But no CEL. I forgot to add that it has a banks transmission controler on it. Been on for 4 months or so. That really tightened up the shift points.
Old Jan 22, 2008 | 08:08 PM
MADVAN's Avatar
MADVAN
The banks will raise line pressure. It fools the EPC.
Cannot really say anything about the issue.
I would recheck the command wiring though.
Just be shure the pins are locked into the connectors. Pull on the wire (each pin) to be shure they do not come out of the plastic housing.
And check all the brake lights. Just to be shure they work and they are not to sensitive to go on.
Bill
Old Jan 22, 2008 | 08:10 PM
tjbeggs's Avatar
tjbeggs
the transcommands I have seen have not been sealed well and actually crumbled in my hand!
Old Jan 22, 2008 | 08:22 PM
heathrunkles
Well I will keep driving it and watch it closely. If it does it tommorrow I have a bypass jumper for the transcommander. I will try that for now and see what happens.
Scruffy
Oct 6, 2012 12:03 AM
weldboy
Oct 26, 2011 07:37 PM
89ford73
16
Sep 18, 2010 06:36 PM
69 stang
Jul 15, 2009 11:03 PM
swamprocket
Jan 26, 2008 09:33 PM
