Can I put my AA injectors in the wifes EX.
I am hoping for better fuel mileage in the EX.
I also thought I could use hers as a core for my II's. I believe hers are Split shot.
Will they take split shots as a core for the single shot II's?
My biggest concern is will the SD PCM run the single shots efficiently or at all.
Just a thought. This way I can tell her I can get her better mileage and then I would HAVE TO buy some Stage II's from DPP or whoever has the best price at the time.
No singles won't run good at all on split shot programming. split will run on single programming but not the other way around. Plus the splits are 140cc rating and the AA's are 90cc. big difference in fuel delivery. As far as the cores go I don't know. YOu would have to ask DPP or who ever you buy from.
Well there goes that Idea. I was thinking of putting my smaller ones on hers to help mileage. I found a receipt from about 3 years ago when I had to put mine in the shop 'cause I wasn't here yet and didn't know what was wrong with it. $4089.70 later I got it back and ran fine.
I got 8 p/n# PS-1100X @ $267.60 ea. I assume injectors based on the price.
F7TZ-12K073-A Syncronizer A. No idea...Anybody?
F6TZ-9350-A Pump Assy-Fue. I assume fuel pump
F4TZ-9N184-A Element. I assume fuel heater.
F4TZ-6731-A Kit-Element. I asume kit for above item.
also one: 505011-K Diesel Kit. Not sure on this one either.
And a partridge in a pear tree.
Oh yeah and I didn't even squeek on the way home, must have used lube. LOL
F7TZ-12K073-A Syncronizer A. No idea...Anybody? CPS
F6TZ-9350-A Pump Assy-Fue. I assume fuel pump fuel pump
F4TZ-9N184-A Element. I assume fuel heater. Fuel filter
F4TZ-6731-A Kit-Element. I asume kit for above item. oil filter
And a partridge in a pear tree. No Clue
They only charged me for 3 quarts of oil, how can they do the oil filter. I wonder if that was the Air filter that I didn't need, that we argued about and I won.
Part number comes up as the oil filter. But maybe they decided to get paid for the air filter anyway by slipping the oil filter. Looks like they don't know what they were doing anyway!
