tranny shifting problems
Old Jul 14, 2009 | 12:24 AM
69 stang's Avatar
69 stang
This all first started off by pulling a boat from a buudies house to mine (maybe 10 miles). The temp ran up to about 200 and i stopped and waited a bit for it to cool down. Now when i start up and go cool it shifts fine but as it warms ups the shift from first to second may happen at normal rpms or i have to let off the pedal and it will shift into second. All other gears are fine. But sometimes it shifts fine. I was going to change fluid and filter. But wondering if this was going to take care of it or should i check for anything else at the same time. Kinda at a loss since dont know much in this area. And no OD light flashing. Any ideas what be greatly appreciated.
Old Jul 14, 2009 | 01:50 PM
aaron ford's Avatar
aaron ford
This is just a guess, but it sounds like your tranny cooler is plugged. I had a similar problem and ended up fixing it with a 4739 tru-cool with bypass.
My tranny runs cooler bypassing the fluid than it used to with the OEM cooler. I would have been better off to bypass the stock cooler and run without it.
I rinsed out the old cooler and it took several flushes to get all the junk out.
You might try pulling the cooler and flushing it out.
Aaron
Old Jul 14, 2009 | 03:06 PM
69 stang's Avatar
69 stang
I have the tru cool 4739 installed right now
Old Jul 14, 2009 | 05:11 PM
aaron ford's Avatar
aaron ford
Have you done a flow test on the tranny? Get it up to at least 100 degrees and disconnect the rear tranny line. Time the discharge. You should get 32 ounces of oil in 15 seconds. Check the inlet line to the cooler, then back to the radiator cooler, then back to the discharge port on the front of the tranny. If low there, you have a pump problem.
It seems like you are not getting the temp drop across the cooler that you should be seeing. I assume this is due to flow.
Aaron
Old Jul 14, 2009 | 06:04 PM
69 stang's Avatar
69 stang
ok you say pump problem. what pump? sorry for the ignorance.
Old Jul 14, 2009 | 07:19 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
He is reffering to the tranny pump, which is located in the frontal part of the tranny, you have to take out the full tranny to get to it.
Old Jul 14, 2009 | 07:33 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
here is an exploded view of the tranny, the pump is in the bottom of the diagram with number 10. (pump assembly)
Old Jul 14, 2009 | 07:58 PM
pjwoolw's Avatar
pjwoolw
Getting good flow through the radiator? If it's still plumbed through the radiator cooler.
Old Jul 14, 2009 | 08:55 PM
69 stang's Avatar
69 stang
thank you for the diagram. explain alot now.
so is it more benefical to run the external cooler with it hook to radiator still or is it preference thing?
Old Jul 14, 2009 | 09:06 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
You are welcome. And most here still conserve the hook to the radiator, is a good thing.
Old Jul 14, 2009 | 11:47 PM
IDMooseMan's Avatar
IDMooseMan
I was having a similar problem with my tranny shifting hard. Turns out it was the Vehicle Speed Sensor (VSS) in the rear differential.
$25 and 20 minutes seems to have taken care of the problem. I installed the new VSS yesterday. 12 month / 12,000 miles warranty.
If you haven't changed the VSS in awhile (or ever) you might want to look at it. If it's fairly new but dirty, wipe it off (don't use any cleaner) and reinstall it. That might cure the problem for awhile.
Old Jul 15, 2009 | 08:28 PM
aaron ford's Avatar
aaron ford
I hadn't thought of it from that angle, IDMooseman. If the VSS was keeping the Torque Converter from locking up, then the fluid would heat fairly quickly... How does your speedo act? Normal, jumpy?
Aaron
Old Jul 15, 2009 | 10:39 PM
69 stang's Avatar
69 stang
the speedo at a constant speed would fluctiate a little. so should i disconnect just the plug and clean that or pull it from the housing and clean the gunk off?
Old Jul 15, 2009 | 10:53 PM
IDMooseMan's Avatar
IDMooseMan
69Stang - If the connectors are dirty, clean them too. Pull the sensor from the diff and wipe it off. I use dielectric grease or vaseline on the plug end to help keep out water and crud.
Aaron - When the VSS is acting up, the speedo is jumpy. I've had the needle drop to the bottom of whatever side it is on and the odometer/tripmeter would blank out and reappear; still accumulating.
Unforetunately, this can also be a sign of a malfuntioning Camshaft Position Sensor (CPS), too.
Old Jul 15, 2009 | 11:03 PM
69 stang's Avatar
69 stang
well i'll give the vss a try first
Texas Chain Ring
Sep 28, 2012 09:14 AM
Texas Chain Ring
29
Sep 22, 2012 12:03 AM
wence5
Aug 21, 2011 07:56 AM
haulingboat
1997 - 2003 F150
Nov 17, 2004 03:33 PM
