Instrument bezels
Old Jan 22, 2008 | 03:24 PM
grnlzrd's Avatar
grnlzrd
Instrument bezels
Are there more than one type? A guy says this one is uncut around the radio, and just needs a faceplate. All the ones I've seen have the smaller opening and holes for shafts.
Old Jan 22, 2008 | 03:26 PM
tellico racing's Avatar
tellico racing
That one has been hacked out to accept a modern radio
Old Jan 22, 2008 | 03:30 PM
grnlzrd's Avatar
grnlzrd
That's what I thought. He swears up and down it is uncut, and just needs this "original" metal face plate.
Old Jan 22, 2008 | 03:36 PM
psquare7575's Avatar
psquare7575
Mine looks exactly like the original poster's, and had an OEM radio with a trimplate just like the bottom one. There are posts on this if you search.
Old Jan 22, 2008 | 03:48 PM
m78's Avatar
m78
That looks like the original that came out of my truck also, and you need the radio face plate.
Old Jan 22, 2008 | 04:03 PM
bucks77ford's Avatar
bucks77ford
That is an OEM bezel. Very common in many trucks (I've seem many) and needs that faceplate either metal or plastic. Why the difference, I'm not sure.
Old Jan 23, 2008 | 06:31 PM
ford4life69's Avatar
ford4life69
I've never seen one like that that hasn't been cut. Mine does NOT have that large gap that would fit a common cd player in it and it is original to the truck. My deck isn't original but shaped to fit the same holes as the original AM only and includes that type of face plate that you can put over it as well. Mine's not on it mostly because it got put in a box and brake fluid leaked on it and made the plastic extremely brittle.
Old Jan 23, 2008 | 06:45 PM
ford390gashog's Avatar
ford390gashog
The one in the picture is cut.
There was 3 bezels from 73-79
1 Vent delete and radio delete
2 Vent delete with radio cut out(will have 2 molded holes in the face plate if uncut)
3 Vent with radio cut out (with the same molded holes as above)
Old Jan 31, 2008 | 07:42 PM
tomcasino's Avatar
tomcasino
Instrument bezel
I have to disagree about the above pictured bezel. I have one out of a 1/2 ton that is not cut. I'm having trouble posting a photo but there's one in my gallery under exhaust. It still had the original AM radio when I removed it. The part number is: D3TB I0045C90.
Last edited by tomcasino; Jan 31, 2008 at 07:51 PM. Reason: Photo did not show up.
Old Jan 31, 2008 | 07:56 PM
fmc400's Avatar
fmc400
MSEE
This is not correct. It is UN-cut.
1973-1977 bezels are different than 1978-1979 bezels. 1973 to 1977 bezels have one big hole for the radio, and then a separate shaft-style faceplate covers the hole. 1978 to 1979 bezels have the radio faceplate permanently integrated into the bezel. All 1973 to 1977 trucks use the separate faceplate to finish the radio covering. There were two types of faceplates - metal and plastic.
grnlzrd, that first picture is an uncut 1973 to 1977 bezel. When you install it, there is supposed to be a large hole over the radio. You need the faceplate in the second picture to complete the setup. 1978 and 1979 bezels are one piece and all plastic. Any modern reproduction bezel is the 1978-1979 type.
propellerhead
15
Apr 25, 2017 12:28 PM
Snowseeker
Oct 27, 2011 12:48 PM
luckyjoe
15
Oct 4, 2010 07:49 PM
ajorn
Mar 2, 2010 01:26 PM
