1978 - 1996 Big Bronco
rear window motor switch
Old Aug 15, 2006 | 09:26 PM
chrono4's Avatar
chrono4
I thought the window in my Bronco was shot, so I pulled the access cover, and put power to the motor, and vawlaw, down it went. I'm pretty sure the switch is shot, but i cant test it because I need to know what wires to cross to go up and down. Anybody know? my haynes manual doesnt show it. Thanksg guys.
Old Aug 16, 2006 | 04:43 AM
greystreak92's Avatar
greystreak92
Which switch... the one in the dashboard or the one in the tailgate? The wiring is slightly different for each one.
Old Aug 16, 2006 | 06:13 AM
chrono4's Avatar
chrono4
the one in the dash.
Old Aug 16, 2006 | 10:50 AM
helirich's Avatar
helirich
You should be able to unplug the switch and see which pin has power (incomming) If no power is there, its not the switch. You can test the switch on the bench. If the switch tests out, you can figure out which pins on the harness go to the gate. And so forth. I'm sorry I dont have the color codes. But often, there wrong anyways. I've been through this several times and its not to difficult. Just be advised that both leeds going to the motor have power when the switch is at rest. (if its plugged in and working correctly)
millerm740
1997 - 2003 F150
Apr 5, 2016 09:26 PM
H20ENG
19
Feb 21, 2013 09:21 PM
uscrpick
Mar 11, 2007 09:08 PM
Zukster
Apr 1, 2005 07:39 AM
