Sponsored by: Real Truck
v10 sputtering!!! what could it be?
Old Jan 17, 2008 | 07:22 PM
rg200amp's Avatar
rg200amp
whats up guys, tonight my truck started to sputter while at a stop while in drive, now it has a sputter while driving.
the v10 has 61000 miles onit. it has a new air filter, new oil+filter, new fuel filter, runs on 89 octain, and i cleaned the MAS + reset the computer about 2 months ago. everything was fine, but just tonight it started the sputtering.
what do you guys think it could be? i dont think the plugs are bad, i checked two and they looked good.
any ideas?
thanks guys, i am really greatfull for your help!
Old Jan 17, 2008 | 07:26 PM
boxcar1974's Avatar
boxcar1974
COP, water in fuel, low fuel pressure, faulty fuel pump.
Could be a bunch of things. Do you have a code reader? Do you have a smell of sulfur?
Old Jan 17, 2008 | 07:29 PM
rg200amp's Avatar
rg200amp
no sulfur smell.
It might be the pressure, im gonna get it tested.
Old Jan 17, 2008 | 07:32 PM
GT4point6's Avatar
GT4point6
Do you have a check engine light/SES/CE? If so, get is scanned. Check your airbox and inlet tube to make sure you don't have a vacuum leak.
Old Jan 17, 2008 | 07:42 PM
rg200amp's Avatar
rg200amp
No codes, scanned it and all.
I just hope its something i can fix
Old Jan 17, 2008 | 07:48 PM
boxcar1974's Avatar
boxcar1974
Sometimes it takes some time for the codes to appear. When my COP went to heck, the truck would hardly run. It would shake the teeth out of your head it ran so mad. The sulfur smell was enough to make you sick. No CEL or codes. It took awhile to get it to toss a CEL.
Very well could be a vacuum leak. They are tricks and wont usually cause a code directly to the leak. Usually some sort of a lean condition.
Old Jan 17, 2008 | 09:08 PM
superdutymj's Avatar
superdutymj
check the PCV elbow on the back of the intake. Should be a 90 degree rubber elbow back there going to your PCV valve. These will usually blow a sizeable hole right at the bend in the elbow. $12-15 fix if i remember right. I had a V10 with similar mileage do this to me and it was this vacuum leak. With that few miles it shouldnt be a cop dropping out on you.
Old Jan 17, 2008 | 09:18 PM
jimmyb08SD's Avatar
jimmyb08SD
Did you recently buy gas? Maybe a $1.00 bottle of dry gas will help, this time of year it cant hurt. May have just been bad gas.
Old Jan 17, 2008 | 09:50 PM
superdutymj
This far into winter i doubt that a bad blend is to blame. Sounds like vacuum leak or spark issue to me.
Old Jan 18, 2008 | 08:54 AM
rg200amp's Avatar
rg200amp
im gonna check the pcv and add a bottle of dry to the gas today, hopefully its something easy!!!!
Old Jan 18, 2008 | 11:24 AM
Jax 99's Avatar
Jax 99
my 99 is doing the same, i found one pcv hose swelled and seperated at a plastic down sizer.
still no code, even tried leaving battery off for a day and now seems worse.
its burning rich as if a vaccum line is open, but i cant find any.
Old Jan 18, 2008 | 01:26 PM
redford's Avatar
redford
FTE Leadership Emeritus
Check your Idle Air Control (IAC) valve.
Old Jan 22, 2008 | 08:13 AM
samuel6's Avatar
samuel6
Check your coils?
Old Jan 22, 2008 | 08:17 AM
redford's Avatar
redford
Also, scan it with a code reader that can read pending codes.
Old Jan 23, 2008 | 08:13 PM
greggraymo's Avatar
greggraymo
I had the same thing happen recently on my '00 F250 and it ended up being one of the coils. I had just bought it nused, so they fixed it for free and it was done by the end of the day. Hope this helps.
Bondsman Chris
Aug 2, 2018 05:32 PM
Nashterbater
May 19, 2017 09:28 PM
wahlturfcare
34
Aug 25, 2013 05:00 PM
Nitramjr
24
Sep 28, 2010 05:54 AM
Drgslayr
1983 - 2012 Ranger & B-Series
Jul 16, 2009 02:49 PM
