99 navigator clunks over speed bumps.
Old Jan 17, 2008 | 02:40 PM
SICKANDTWYSTED's Avatar
SICKANDTWYSTED
99' navigator 2wd 32v 5.4 with 100k miles
when you got over a speed bump or a large bump in the road that compresses the front suspention it makes a click-clunk sound everytime. i was told that these have a sway bar problem were it hits the frame, but i cant see anywhere its doing that. anyother ideas like ball joints or wheel bearings, how do i check those?
Old Jan 17, 2008 | 05:39 PM
Modified 99's Avatar
Modified 99
Look at the ENDS of the sway bar. If it is not connected or is not solidly connected you may be looking at your clunk issue.
Old Jan 17, 2008 | 06:05 PM
madsonp's Avatar
madsonp
There are also two inner sway bar bushings that could be bad also. Just follow your sway bar from one side to the other and you'll see them.
Old Jan 17, 2008 | 09:01 PM
bobthebuilder1651's Avatar
bobthebuilder1651
I recently replaced the sway bar bolts that connect it to the A frame. Its a fairly easy job. I'll bet thats where your "clunk" is coming from. As mentioned, just chekc the ends of your sway bar. Best luck....
Old Jan 27, 2008 | 08:13 PM
Gevans17's Avatar
Gevans17
clunking front end
check your front shocks...both of mine were fractured off at the lower end where they attach to the control arm
Old Jan 27, 2008 | 09:17 PM
outlawspeeder88's Avatar
outlawspeeder88
Everyone is telling you to check all the right things. Check them all. Also look for anything left under the hood, look for anything moving around... If it is a 4X4 the ball joints are a pain.
Old Jan 28, 2008 | 03:46 PM
TriniWolf's Avatar
TriniWolf
Lightbulb Clunking over bumps
I'm a relative nuby to DIY, but I recently fixed a similar problem. Just drive up on some ramps and from under the vehicle look in line with the wheels., you should see two staight shafts that look like mini struts/shocks. Check to see if they are loos or worn. I puchased a front end repair kit from Autozone for $20 and did the repair for myself in about 1/2 hr, no knocking since then, but I still have other suspension issues to resolve later.
Old Mar 23, 2008 | 03:08 PM
SICKANDTWYSTED
ok the wife went through knee surgery so i just got back to this but i figured it out. i was tightening the sway bar mounts when i noticed the p/s upper shock bushing was gone. i dont know how i missed it before (the shocks was the first thing i looked at) but never the less i didnt notice till now. so I went ahead and replaced the stock shocks (at 125k) and the noise is gone and the ride is smoother, should have done this along time ago.
Old Mar 23, 2008 | 04:19 PM
madsonp's Avatar
madsonp
Gald to hear it, thanks for sharing the outcome with us.
rednekrebel28
20
Dec 29, 2010 07:45 PM
aristocraft
17
Feb 25, 2010 10:33 AM
ckstrawser
25
Dec 22, 2009 09:57 PM
2000navi
Nov 30, 2009 12:37 AM
PhilipC
Dec 8, 2003 04:30 PM
