My e99 clunks only at certain times. Here's when. When one of the front tires hits a bump, it will clunk. Sounds like the front end. But if both front tires hit the bump, like a speed bump, there is no clunk. If the back tires, hit a bump evenly, there is no clunk. If one back tire hits a bump, there is a clunk still sounding like its coming from the front. And here's the real tester. When i get on the throttle hard, and let out quickly as its fully spooled, it clunks. ( you know how like the front of the truck raises then sits as soon as you let out, it will clunk then) And sometimes when the tranny shifts hard it clunks, but that could very well be just the tranny I was thinking maybe motor mounts? trans mounts? cab mounts? Any one else every run into this? could it possibly be sway bar or track bar bushings?
Start with the cheaper fixes and check those swaybar bushings, mine were shot and got a nice kit and replaced, no more clunk. Second, raise the front end off the ground, get a breaker bar under the front tires and lift up, any play your ball joints are bad, do the same for the other side. If it is your swaybar bushings, let me know, I know a great place to get them and for cheap, polyurathane to boot.
guess i should of mentioned that too. The ball joints are brand new, absolute no play, and the slip joint was just greased maybe 3000 miles ago. i did how ever just put new sway bar bushings on the axle housing because the bracket on the axle broken and had to be welded back on so i figured put new ones on while it was off. Now the bushings you all are talking about, the sway bar end link bushing or actually sway bar bushings? Could i have bought the wrong bushings and that cause this? (not in the end links)
The endlinks are the vertical rods that attach to the ends of the swaybar and the frame. There are bushings at each end.
