Bump, clunk, bump, clunk
Old Jan 1, 2006 | 07:49 PM
ckstrawser's Avatar
ckstrawser
I have a 2000 Ford Explorer, XLT, 4x4, 4.0L, Driving the vehicle over bumps t at normal speeds (50-60 mph) the front suspension seems to perform as it should taking the bumps as it should, no clunks or bumps. But, when driving the vehicle over small bumps (for example in a parking lot, or over my relatively smooth front yard) the front end makes noises as if it is going to fall off. It makes a clunk, clunk, bump, clunk noise. I am not making any turns just driving straight, but it does make the exact same noise when turning. I have replaced the shocks to attempt to remedy the noise, but to no avail. All the bushings look good, but that doesn't mean anything. Took it to the dealership and they said everything checked out according to Ford specs. Any ideas would be much appreciated.
Old Jan 1, 2006 | 08:02 PM
9explorer8's Avatar
9explorer8
Just a wild chance, but is the hood closing as tightly as it should? At speed, air flow may be holding it down a bit more, thus no clunking as when at low speed. Probably not the problem, but worth a quick check. On my 1998 Explorer there is no up or down play when the hood is closed. Sometimes hard to tell exactly where those clunks are coming from.
Good luck
JD
Old Jan 2, 2006 | 06:53 AM
ckstrawser's Avatar
ckstrawser
On a real quick check, the hood is tight as a drum. no bounce or play there.
Old Jan 2, 2006 | 07:54 AM
9explorer8's Avatar
9explorer8
Is this a problem that has recently started or has it always made this noise?
Old Jan 2, 2006 | 09:52 AM
MountaineerAWD's Avatar
MountaineerAWD
sway bar bushings?? The only reason I say that is becuase mine had that problem when I brought it, but granted, mines an 02, so I don't know if the sway bar is different in the 2000 modle?
Old Jan 2, 2006 | 04:01 PM
ckstrawser's Avatar
ckstrawser
This is a problem that has just recently started probably about 6 to 8 months ago, roughly around the start of summer and has slowly gotten worse. The truck has 85,000 miles on it
Old Jan 5, 2006 | 05:21 AM
afinepoint's Avatar
afinepoint
cks,
My 92 has a clunk on the front left side. Sounds like a brick loosely tied to the suspension. It occurs at low speeds as well as when turning at speed, particulary right turns. The harder and faster the turn the louder the noise. I have read in this forum of others with Explorers that go clunk in the night (and day). Some feel that it is "normal these trucks but I don't like hearing it.
On mine I feel it is brake component related or a dried out or worn bushing. The ball joints have no play in them.
The truck has been making this noise for thousands of miles. Neither I nor a garage have been able to find anything. The only thing I feel I can do it wait for 100% failure. Although the thought of loss of steering control at speed gives me no comfort.
My truck has 238,000 miles on it. The radius arm bushings have been changed.
Reg
Old Jan 5, 2006 | 12:40 PM
Jharger's Avatar
Jharger
I have a heavy left front clunck too. I'm convinced it is a ball joint since when I first lifted the truck, the clunck went away. The lift and camber alignment changed the seating of the ball joints. Well the clunck is back now under heavy braking or hard turns and all the time off road under those loads/articulations. I've got 4 ball joints sitting on the bench - got delayed when tranny dies last week.
Old Jan 6, 2006 | 04:32 PM
afinepoint's Avatar
afinepoint
J,
Post the results of the ball joint change. If the problems disappears . . well the rest of us know what must be done.
Reg
Old Jan 9, 2006 | 11:30 AM
Jharger's Avatar
Jharger
OK will do. I'm just as curious as you on this one. now that the tranny is back in, this will be the next project.
Old Jan 9, 2006 | 11:43 AM
swandog's Avatar
swandog
I'm also waiting to see your results...I have a 2000 explorer that is doing the exact same thing....90k miles....started last summer...and it's driving me crazy always listening to the clunck and trying to visualize what is causing it...I replaced the sway bar bushings but that wasn't it...I was looking at the bushing for the sway bar connecting it to the arm and/or the radius arm bushings....but I will hold off on that mess for now...thanks
Doug
Old Jan 9, 2006 | 12:30 PM
Jharger's Avatar
Jharger
Every bushing in my suspension is now polyurethane. Bushings aren't my clunk. I can feel it too, especially on hard braking. So it's definitely some play in one of the metal components. Wife has a marathon to run this weekend so I can't get to this for a couple weeks earliest.
Old Jan 10, 2006 | 01:02 PM
swandog's Avatar
swandog
No problem, I can wait....it's too cold in Minnesota right now to be crawling under my truck without a better idea of what I should be focusing on...
later
Doug
Old Sep 16, 2006 | 08:13 AM
DBray6's Avatar
DBray6
I have this exact problem in my 97' explorer. Only at low speeds over bumps. (Parking Lots etc.) Has anyone figured this one out. My garage also cannot locate the problem.
Old Oct 1, 2006 | 03:25 PM
DBray6's Avatar
DBray6
I still haven't figured this one out......
