Aerostar Ford Aerostar
coolant temp sender
Old Jan 19, 2008 | 10:47 AM
DaveMac2Vans's Avatar
DaveMac2Vans
My thermostat is a 195° item, but it is supposedly a fail-safe type (all they had the day I was replacing mine). My guess is that I need to replace it and flush the system to see if something might have broken loose and is plugging a heater somewhere. I had to replace that little vacuum-operated valve that goes to the front heater core last year. Maybe a piece of that broke off and gor in someplace tight.
I wonder why these play-with-the-water projects always happen on 31° days instead of in July or August.
Old Jan 19, 2008 | 02:32 PM
96_4wdr's Avatar
96_4wdr
tk,
would suspect the vac. valve is in the hot in line to prevent hot coolant in the heater core while in A/C mode
and A/C systems only break down in the dead heat of summer when all the a/c shops are plugged and the van is supposed to go on vacation tomorrow?
Old Jan 19, 2008 | 02:45 PM
DaveMac2Vans
Originally Posted by 96_4wdr
96, that link with the photos is great! Is there a location chart that tells where those are hidden? There are a couple there I have never seen before.
Old Jan 20, 2008 | 06:09 AM
tk1251k's Avatar
tk1251k
I do remember before having a problem that the line opposite line with water vac into heater core stayed hot. The line coming out of the core inot heater vacuum was cold. I would have thought as you do the valve would come first to stop hot water but apparently not. I bought the van new nothing ever changed on it except by me. thanks
Old Jan 22, 2008 | 08:00 AM
tk1251k's Avatar
tk1251k
Would love to see pictures of the two lines underneath van with rear heat just before they connect to heater core and coolant valve also located just before lines connect to heater core. thanks tk
SC F250
Jul 15, 2017 03:11 PM
f150country
Dec 1, 2016 10:53 PM
SSSimon
18
Oct 25, 2010 07:21 AM
carrfamilynj
Sep 23, 2006 09:54 AM
joners
Apr 2, 2006 02:29 PM
