temp sensor resistance
Old Apr 2, 2006 | 12:07 PM
joners's Avatar
joners
What should the temp sensor resistance read for a 97 Explorer 4.0 OHV? Does ohms=temperature?
I'm getting exactly 50 degress difference between infrared thermometer and multimeter reading. 120 ohms vs 170 degrees.
Truck has 180k, assuming temp sensor has never been replaced. I couldnt find any info about resistance range for temp sensor in my Haynes manual. Also, this is for the gauge sensor, not the ECU.
Old Apr 2, 2006 | 12:28 PM
Bob Ayers's Avatar
Bob Ayers
No OHMs does not = temp (degrees)!!! Matter fact, the resistance of most temp sensors is inversely proportional to temperature!!
Old Apr 2, 2006 | 02:00 PM
joners's Avatar
joners
Anyone have specs on what the resistance should read?
Old Apr 2, 2006 | 02:10 PM
Bob Ayers's Avatar
Bob Ayers
I don't have the information for a 97, but for a 2000, HOT = 16 OHMS, COLD = 275 OHMS. I would think they would be about the same.
Old Apr 2, 2006 | 02:29 PM
Dialtone's Avatar
Dialtone
courtesy of http://www.carsoft.ru/autorepair/gtest.pdf (table on page 38)
ECT and IAT sensor readings (this applies to 95 Explorer, but should serve as a good general guide)
Temp deg F (deg C) Volts Resistance (ohms)
50 (10) 3.51 58,750
68 (20) 3.07 27,300
86 (30) 2.60 24,270
104 (40) 2.13 16,150
122 (50) 1.70 10,970
140 (60) 1.33 7,700
158 (70) 1.33 7,700 (one of these 2 is wrong)
176 (80) 0.78 3840
194 (90) 0.60 2800
212 (100) 0.46 2070
Dialtone
edit (post re-aligns the tablular format so insert spacing as appropriate)
edit 2 this does NOT apply to the gague sensor
Roader
24
Jul 21, 2024 08:27 AM
mainiac1
May 26, 2010 09:26 PM
BURNSTOUGHFORD
1997 - 2003 F150
Oct 21, 2009 09:23 PM
mich52
Dec 30, 2003 12:47 PM
