GP Control switch
Old Jan 16, 2008 | 08:58 PM
BOBSDIESEL's Avatar
BOBSDIESEL
Question GP Control switch
I have been having problems with starting my truck and a buddy of mine looked and my chiltons and thinks that my problem may be my Glow Plug Contol Switch. I guess it threads into the "left cylinder head coolant jacket" Has anyone ever had to replace this swicth and does anyone know part #'s? Thanks a bunch
Old Jan 16, 2008 | 09:04 PM
tjbeggs's Avatar
tjbeggs
Nope it doesn't exist! Chiltons might be for an IDI. The Glowplugs are controlled by the PCM and refer to the oil temp, barometric pressure and I think the Intake air temp to calculate GP on time.
Check the relay with key on for power on both larger lugs. this is best with two people so you don't have to wonder if the relay already turned off. If you don't have power on both and the relay clicks you need a new relay. if you have power on just one and no click you either need a relay or there is a control side problem. The PCM controls the ground side of control circuit. so one of the small terminals should have a constant 12 volts with the key on.
Old Jan 16, 2008 | 09:07 PM
BOBSDIESEL's Avatar
BOBSDIESEL
I've already changed out the GP relay 3 times since the problem started a couple months ago and it melted out one of the large posts on one and has been having hard/no start for what seesm like forever...
Old Jan 16, 2008 | 09:10 PM
tjbeggs's Avatar
tjbeggs
Time to check the ohm readings on the GP. Also could be shorted to ground. Might need to pull the valve covers and make sure none of the wires are rubber a push rod.
Old Jan 16, 2008 | 09:11 PM
BOBSDIESEL's Avatar
BOBSDIESEL
you knw TJ i never even noticed before but the book does say 94-96 DI turbo...
Old Jan 16, 2008 | 09:18 PM
BOBSDIESEL's Avatar
BOBSDIESEL
ok. i tried to figure out how to test the resistance but no one could really explain in simply enough for me. Care to try?
Old Jan 16, 2008 | 09:19 PM
tjbeggs's Avatar
tjbeggs
Seems like it would be right then. I would check for power on both large terminals again just to make sure its energizing.
I just noticed you live in SoCal. is your truck a cali emissions?
Old Jan 16, 2008 | 09:21 PM
BOBSDIESEL's Avatar
BOBSDIESEL
I honestly have no idea if its a Cali truck
Old Jan 16, 2008 | 09:22 PM
tjbeggs's Avatar
tjbeggs
http://andersonimprovements.com/hobb...sandrelay.html
Old Jan 16, 2008 | 09:48 PM
BOBSDIESEL's Avatar
BOBSDIESEL
Uhhh my GPR is reading a little over 18 when the key is off...
jbdII
Bronco II
Aug 11, 2010 08:44 AM
kxmurray
Apr 14, 2007 12:31 AM
johnsf
Apr 11, 2006 06:51 AM
cubabrian
Electrical Systems/Wiring
Mar 4, 2004 02:20 PM
D Ray
Aug 19, 2002 12:50 PM
