Headlight switch
Old Apr 10, 2006 | 08:18 PM
johnsf's Avatar
johnsf
Headlight switch
I hate to say this but I have a Ch^#y headlight switch in my 56. I'm replacing it and I found a new switch but I'm having a problem get the rod that goes into the switch to work. It won't engage anything inside the switch so I can pull out the switch to turn on the lights. Anyone have any ideas
John
Old Apr 10, 2006 | 10:44 PM
51ford fan's Avatar
51ford fan
Are you depressing the spring loaded button on the underside of the switch while pushing the rod in, that button locks the rod in place. If you are try spraying some WD-40 and install it again
Rod 51F1
Old Apr 10, 2006 | 11:49 PM
Brian_B's Avatar
Brian_B
What he said. Every brand of switch I have seen has the spring. Ford or Ch**y. If its not pushed when the rod goes in, it won't enguage.
Old Apr 11, 2006 | 06:51 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Make sure that the length and diameter of the rod you want to use matches the rod that came with the switch originally. They are not of universal length and diameter. The rod you are using may be too short or the diameter to large to lock in place. I've been down this road before...
Vern
john fin
Jan 9, 2020 10:19 AM
scotttahoe
Oct 9, 2013 05:38 PM
John Aary
Apr 19, 2013 07:39 AM
tucn26s
Apr 11, 2010 10:50 PM
