door hinge pin removal
Old Jan 15, 2008 | 03:50 PM
mike330's Avatar
mike330
Anyone have a easy way of removing the pin on the door hinge without removing the hinge?
Old Jan 15, 2008 | 05:58 PM
wpinef's Avatar
wpinef
brace the door with a floor jack and cut it off with a sawsall. take your time and don't let it slip.
Dave
Old Jan 15, 2008 | 07:34 PM
92mnfordtrk's Avatar
92mnfordtrk
Use a dremel tool, $30 at store comes with bits and stuff, use the cut-off wheel, it is small enough the fit in there. If you need more cut-off wheels they are cheap and found where you bought the dremel tool. Don't buy just the tool because then you have to by the cutoff wheel with the stem adn stuff, plus for $30 you can't argue with the accessories.
You might need extension cord too
Edit: Yeah brace with a floor jack or throw arope through a tree or garage rafter or door rail etc. to get the door level how its supposed to be. Also for $6 do the other side too so that you won't have to do it later is some really cold weather etc.
Old Jan 15, 2008 | 07:46 PM
quicklook2's Avatar
quicklook2
too late, it i really cold weather now.
Gwilkrrs
22
Dec 11, 2023 02:38 PM
psycoreefer
Aug 28, 2015 11:38 AM
48fordcoe
15
May 21, 2012 05:33 PM
ralphhood3
25
Jan 7, 2012 07:01 PM
cberger627
Sep 16, 2009 02:58 AM
