05+ gauge cluster problems?
Old Jan 14, 2008 | 12:42 PM
sneak's Avatar
sneak
Are there lots of people out there who have problems with thier gauge clusters reading random/severly wrong numbers for the tack and speedo?
Old Jan 14, 2008 | 01:39 PM
koboss1's Avatar
koboss1
I have had wierd readings on my tach...it will show over 4000 revs and im only 2500rpm, let off accelerator and it rights itself?
05 KingRanch SD CC
Old Jan 14, 2008 | 07:18 PM
Harkes2k's Avatar
Harkes2k
I have similar problems where my 06 wont reset back to 0 all the time on the tach... sometimes it starts at 2k and stuff
Old Jan 14, 2008 | 10:52 PM
tazo's Avatar
tazo
Seems like we all have something in common. My 05 has erratic tach readings. But it only happens once in a while. It happened to me yesterday while towing. So I pulled over and turned the motor off for a minute and then restarted her. Tach was showing 1500 rpm's at idle. A minute latter it corrected it self and read normal. I use it when towing so I know when to shift since I will rev her all the way up to 3300 to 3500 between shifts. If anyone knows a cure I would be curious to here about it.
Old Jan 14, 2008 | 11:08 PM
anmetcalf's Avatar
anmetcalf
Both a friend of mine and I have had new gauge clusters put in. Now neither of us are having any problems. It is a known problem
Old Jan 14, 2008 | 11:32 PM
zrt600guy's Avatar
zrt600guy
Anyone have any lighting issues on the cluster? The left side of the tach on my '05 hardly lights up when it is cold, but then after a couple minutes it has full brightness again. Just wondering if that is a symptom of anything.
Old Jan 15, 2008 | 11:24 AM
sneak's Avatar
sneak
It could be that your alternator is taking a little bit to kick in, I know mine does.
clinte89
16
Mar 9, 2015 07:11 PM
rjohnson_15
Dec 25, 2012 09:42 PM
pipman76
Mar 3, 2008 06:35 PM
fslay
Electrical Systems/Wiring
Aug 25, 2006 10:17 PM
Nathan
Jan 14, 2003 09:46 AM
