65 gauge cluster not working?
Old Dec 23, 2012 | 03:32 PM
rjohnson_15's Avatar
rjohnson_15
The gauge cluster in my 65 is not working but my lights, heater, whippers work. any idea what the problem might be? thanks
Old Dec 23, 2012 | 04:53 PM
jowilker's Avatar
jowilker
Can you be more specific with what is/is not working in the cluster?
John
Old Dec 23, 2012 | 05:40 PM
gangstakr's Avatar
gangstakr
What's a whipper?
Old Dec 23, 2012 | 05:54 PM
F250GH's Avatar
F250GH
Something that you snap...
I knew someone would want an ICVR after I got rid of the ones I tried to sell for over a year. I had NOS Instrument Cluster Voltage Regulators that I parted out. It is probably the part you need if the gauges are not powering properly.
Old Dec 23, 2012 | 07:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by F250GH
I knew someone would want an ICVR after I got rid of the ones I tried to sell for over a year. It is probably the part you need if the gauges are not powering properly.
B9MZ-10804-C .. ICVR ~ Instrument Cluster Voltage Regulator (Motorcraft GR-508) / Obsolete, available from autoparts stores.
Applications: 1965/66 F100/1100 / 1966/77 Bronco / 1967/69 N/NT/T500/1000 / 1967/69 F800/1000 // 1959/66 Galaxie/Thunderbird / 1960/65 Falcon/Comet / 1962/65 Fairlane / 1965/66 Mustang.
The little charmer bolts to the back of the instrument cluster. Take the old one with you to the parts store to match it up.
There are TEN other types used from 1957 thru 1991, chain autoparts store parts clucks haven't a single clue.
Old Dec 23, 2012 | 10:24 PM
The Masked Rider's Avatar
The Masked Rider
BOY John,,, "is/is"... ;o).... Like Clinton I COULD have an answer for that but it might be deleted. HAAaaaaaaaaaaaaa
Old Dec 23, 2012 | 11:14 PM
daveengelson's Avatar
daveengelson
Posting link to diag. out of the 10 page 65 wiring manual, ya may find the manual helpful, most Ford part supplier's carry them; or, order directly from source, Jim Osborn reproductions for $7, found it very helpful in tracing down electrical gremlins. Also, on my 66 custom cab with the plastic instrument cluster I ran a separate ground wire from metal portion of the cluster to a ground connection on the steering column bracket.
http://i300.photobucket.com/albums/n...reDiagP5-1.jpg
Old Dec 24, 2012 | 01:23 PM
William's Avatar
William
If you have the sweep speedometer with plastic housing a missing ground wire may be the issue? Look on the back of the cluster at the metal part that holds the lights and IVR. You should see a ground wire that connects the cluster to the clutch/brake pedal support bracket. Should be black. Replacement should be longer to allow you to pull the cluster out a bit and change a bulb or get your hand in there to disconnect the speedo cable. From Ford these ground wires were too short and are often broken. IMHO! Merry Christmas everyone.
Old Dec 25, 2012 | 04:24 PM
rjohnson_15
ok thanks for the help! I will give it a try.
Old Dec 25, 2012 | 05:20 PM
daveengelson
If oil, temp, fuel, etc., gauges are malfunctioning then it's an indication the CVR is faulty, seen in post #7 wiring diag. The CVR regulates voltage and oscilates between 0 to 10 volts, can be checked with volt meter. Also, check to make sure all the guage connections are secure, in particular the CVR is securly attached to the metal portion of the instrument cluster. Suggest purchase couple extra ground straps and install where needed, can be bought at most auto parts store. After cleaning the grounding surfaces I purchase a small tube of dielectric grease and apply a dab, also some in the wire harness connectors. Anyhow, food for thought!!
Old Dec 25, 2012 | 09:42 PM
tbm3fan's Avatar
tbm3fan
There is also a solid state electronic CVR made for us now. These are starting to show up for older cars and trucks. Installed one on the Polara which was a major pain in the a** but eliminated a weak spot for me. Just bought the new one now available for our trucks from NPD and it will be a whole lot easier to install.
Arizona97
Dec 20, 2017 05:35 PM
Tractionless
6.4L Power Stroke Diesel
Jul 19, 2017 03:50 PM
buzzy613
Jan 14, 2014 07:01 AM
351Cleveland C4
Dec 8, 2013 12:58 AM
sdloe
Jul 27, 2010 07:25 AM
