power steering bracket
Old Jul 24, 2002 | 10:56 PM
onetonford's Avatar
onetonford
Im trying to put a 460 in a 79 f-350 4x4.The pump is hitting the steering box.Is L&L my only choice for a bracket or can someone help me here?Im using the brackets off a 77 f-150 with a factory 460 with a.c.
Thanks
Gregg Adams
Old Jul 24, 2002 | 11:06 PM
gray79f250's Avatar
gray79f250
I had the same prob. in my 79 250. I modified a 351 setup to work mounting it higher temporaily. My freind has a setup of a lincoln 460 with the metal canister pump and that mounts up high to clear the box. Im looking for one myself but am unsure if you could use the air may need everything off the right engine.
Good Luck Andy
Old Jul 24, 2002 | 11:53 PM
merc460's Avatar
merc460
I am having the same problem. I good meaning friend gave me a bracket that he said was for a 460 but it was for a 400, now I must try to modify it or try to find a proper non a/c ps bracket Eric
Old Jul 25, 2002 | 12:01 AM
Superdave's Avatar
Superdave
[updated:LAST EDITED ON 25-Jul-02 AT 01:03 AM (EST)]I used brackets from a 460 that came from a 79 E-250 van and it sets the pump and alternator high with no clearance problems. I had to change over to the saginaw steering pump though. Thats the "metal canister" one mentioned above. Just had NAPA make me a custom high pressure hose and I was good to go.
Old Jul 25, 2002 | 11:21 AM
georgedavila's Avatar
georgedavila
I used '73 Lincoln acessories, including the A/C. I have about 3/4" clearance between the p/s pulley and the steering box, but use L&L motor mounts, so I'm not worried about contact being caused by a broken mount. Before I went to L&L mounts, I was breaking stock F250 mounts and have some nice grooves on the steering box. But this is a Bronco, not an F series.
Old Jul 25, 2002 | 05:30 PM
Steve_Uzi's Avatar
Steve_Uzi
I used the power steering bracket that came on the 429 Thunder Jet from the 1970 T-bird. The T-bird is were I got my 429 that was built into my 460.
Old Jul 25, 2002 | 09:05 PM
onetonford's Avatar
onetonford
Thanks for the help.Are all of your trucks 250 or 350 because the steering box is on the inside of these a 150 is on the outside.
Thanks
Gregg
Old Jul 25, 2002 | 10:38 PM
gray79f250's Avatar
gray79f250
Yep onetonford in the 150 or bronco you can use the darn 351m ps bracket with no probs. My 460 actually came out of a 150 4x4 in the junkyard that was wrecked. I thought I had the alt. and ps setup licked well I was wrong again lol.
Old Jul 26, 2002 | 11:52 PM
Paarrothead's Avatar
Paarrothead
scfarmerjack
Dec 18, 2014 09:50 AM
wisp07
1997 - 2003 F150
Aug 9, 2011 09:21 PM
onetonford
Jul 4, 2003 03:47 PM
onetonford
Aug 6, 2002 11:06 PM
onetonford
Tennessee Chapter
Aug 1, 2002 02:18 PM
