HELP!!!! 460 BRACKEETS
Old Jul 28, 2002 | 07:24 PM
onetonford's Avatar
onetonford
I have put a 460 in my 1979 f-350 4x4!I used L&L mounts a lakewood blowproof and heddman meaders.These headers were 400 bucks and had to notch the cab mounts!!!!!!!NOT VERY HAPPY!!!!!!I bought a 77 f-150 with a 460 for donor parts.I started to put the brackets on and guess what?????Nothing works.Pump hits steering box and alt. hits crossmember.Is there any factory brackets that will work.L&L sells a set but they are 600 bucks!!!!!!Im on a budget(after the 400 dollar headers that didnt fit). I am a machinist and can make or alter them if need to.Any help i wpild appreciate.
Thanks
Gregg Adams
Old Jul 28, 2002 | 08:52 PM
supercab4x4's Avatar
supercab4x4
try performanceunlimited.com
Old Jul 28, 2002 | 09:49 PM
bandit99's Avatar
bandit99
Gregg, look for the 460 from a van or ambulance. I've got pics posted on my site of the set i found and used on my F250/Bronco hybrid. The Saginaw ps pump sits nicely above the ps gear and the turns the 17/40 GroundHawgs with ease. The big-case 70 amp altenator is also mounted up high above the frame rail. These came from a 75 ambulance but the regular van should be the same. If you would like more pics let me know. I'll look,I think I wrote down the casting numbers also.
Old Jul 29, 2002 | 04:12 PM
onetonford's Avatar
onetonford
Trey
Thanks a lot ill hit the yards this week looking for brackets.Great site!!I like thw bronco.
Thanks
Gregg
Old Jul 30, 2002 | 12:49 PM
LxMan1's Avatar
LxMan1
You can also probably use a saginaw PS pump from a lincoln. It will have the a/c bracket built in but you can cut it off. Just block off the upper return port ( it has 2 for the hydroboost system). It will put the pump up much higher that the Ford truck pump assembly.
Old Jul 30, 2002 | 01:00 PM
79Supercab's Avatar
79Supercab
Yeah, I had the same problem. I used the lincoln brackets for the PS pump. Although, instead of cutting off the AC portion of the bracket, I just rotated the entire bracket up so the AC portion clears the PS gear. I just used the highest bolt in the head and then rotated the bracket around that bolt. Then I welded another tab on the bracket to pickup a bolt on the water pump. I have a total of (4) bolts holding the bracket to the engine.
I then plan on running the AC off of the PS pump.
Hopefully it'll work..........?
But, getting the brackets off of an ambulance is the best solution.
Ryan.
78 F250 Ranger XLT Supercab 4x4
460, C6, NP205, D44, D60, 4.10's, 33x12.50x16.5 tires
71 Bronco, 302, C4, PS, PDB (1/2 complete with rebuild)
Old Jul 30, 2002 | 06:17 PM
bandit99's Avatar
bandit99
Ok guys, here's the numbers that I got off my brackets, I don't know if they are still available at the dealer or not. AC bracket= D5UA-2882-AA, water pump pulley= D5UE-8509-DA, crank pulley= D5UE-6312-BA, hi-mount 70A altenator bracket= D5UE-10039-AA, altenator pivot bracket D5UE-10145-AA. Sorry but looked all over the ps braket and didn't find a single marking. I'm thinking that the dealer can probably use the numbers above along with his book's applications for a 75 Econoline and track down the number on the ps bracket. I'll try to take some better pics this weekend and post them on my site....Trey
Old Aug 1, 2002 | 06:15 PM
onetonford's Avatar
onetonford
Trey,
Thanks for the numbers.Went to the local ford place no luck. They gave me a phone number for a place they buy all there obsolete parts from.Called them and guess what!!!!!!!!!!!!You got it no luck.If anyone has the number for a yard that might have these no matter where i would like to have it.460 powered vans werent to popular around here in tennessee i guess.
Thanks for the help everybody!!
Gregg Adams
Old Aug 4, 2002 | 08:10 PM
masterbeavis's Avatar
masterbeavis
I had the same problem. What I did to correct it was find the passenger car saginaw pump setup(as mentioned earlier), use a 2 groove alt. pulley, and the passenger car pulleys. Problem solved (though it ain't purdy no-mo.)
Tony
'77 F250, 4X4 460 transplantee, "Flamer"
'74 F250. 460, "beater" now "1 dead ford"
'73 F250, "midnight auto" now a trailer for the flamer
Old Aug 4, 2002 | 09:42 PM
30over's Avatar
30over
Hey Greg,
I have just ran into the same problem with my 77 highboy conversion.
I have been running the high mount saginaw power steering set up with the low slung big Lincoln alternator in my 2wd 76 F250. It kind of preturbed me to when I was letting my 460 and C6 down into my highboy chassis yesterday, when the alternator mount started to hit about 2 inches before the passenger side mount hit the perch. AAARRRRGGGGG . I live in Tennessee to. Good luck to you on finding mounts. Maybe it will be worth it this winter when go powering through the snow drifts.:7
Old Aug 5, 2002 | 12:03 AM
LxMan1's Avatar
LxMan1
Do you have a truck oil pan or the one out of the lincoln? I am needing one from a 2WD truck for my 77. The car pan puts the drainplug right next to the frame cradle and it taked magic fingers to change my oil. Plus it doesn't hold as much oil. Will the pan you have fit in the 4X4? If not and it is a truck pan, let me know.
Jimmy
Old Aug 5, 2002 | 10:44 PM
onetonford's Avatar
onetonford
I used the pan from a 90 4x4 truck it has the rear sump.You will nees a pan from a 2wd truck.I do not have one but you could weld another drain plug in your pan on the side.Hope that helps.
Still aint found my brackets yet!!!!Anybody got a set laying around???
Gregg Adams
Old Aug 5, 2002 | 10:59 PM
Mil1ion's Avatar
Mil1ion
You guys always have to ask a day AFTER I'm at the wreckers instead of the day before.
I'll keep my eyes open for you.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 6, 2002 | 09:24 PM
onetonford's Avatar
onetonford
If you find some brackets from a van let me know.
Thank you for the trouble
Gregg Adams
Old Aug 6, 2002 | 11:06 PM
LxMan1's Avatar
LxMan1
Tartersauce53
16
Apr 26, 2017 05:27 PM
greentruck72
Apr 7, 2017 11:11 PM
banjopicker66
Sep 8, 2007 03:43 PM
bulrydr_1
Feb 15, 2005 05:34 PM
FlowmasterMan
Nov 28, 2001 09:17 AM
