hook up a set of short lines to the fittings, and run the line ends back into the reservoir.
clamp the master gently into a vise, and with a screwdriver or pin-punch, pump the master till no more air comes out of the lines.
i prefer to hook it up in the truck, and pump it in the truck with the pedal. once all the air is out, then i will hook the lines from the truck up and finish bleeding the brakes.
