Sponsored by: Kumho
bench bleeding master cylinder
Old May 20, 2007 | 11:15 AM
78 Ranger's Avatar
78 Ranger
how would you bench bleed a master cylinder before installing it on the booster
Old May 20, 2007 | 12:38 PM
tjc transport's Avatar
tjc transport
i ain't rite
connect lines to the master, and put the ends of the lines into the masters fluid reservoir. fill the reservoir up.
get a large dowel that fits into the piston center and holding the master, push the piston in. do this till you no longer get air coming out of the lines. it usually takes 8 to 10 pumps.
mount the master on the booster before removing the lines and hooking up the trucks lines. this will make bleeding the trucks lines easier.
makuloco2000
1997 - 2003 F150
Jun 7, 2014 09:40 PM
johaner78
Jan 25, 2014 10:58 AM
aidandj
Aug 26, 2013 03:35 PM
Blue80
Oct 23, 2009 10:11 AM
jc47
Oct 21, 2007 11:53 AM
