tcase on 2wd trany
Old Jan 9, 2008 | 08:01 PM
89toyhauler's Avatar
89toyhauler
tcase on 2wd trany
I have a 7.3 and auto trany from a 2wd truck. The truck no good any more and i found a 4wd gasser with a blown motor i would like to do a swap. What i need to know is if i can take the tail housing of the 7.3 trany off and bolt on a tcase or do i have to have a 4wd trany? And, if so do i have to get a diesel tcase or can i use one out of a gasser? The truck i'm buying is a 94 f150 4x4. I'm expecting that tcase won't work.
Thanks,
Jonathan
Old Jan 9, 2008 | 09:06 PM
PLC7.3's Avatar
PLC7.3
The BW 1356 Tcase was in place on all F150, 250, 350 and Bronco vehicles of the 7.3 vintage. So you should be ok with that part, but the 2wdrive tail housing will not convert......conversion requires the complete insides be removed due to the main shaft being different.... sorry. Also the gasser will have a different trans not adaptable for diesel use......sorry again.
Old Jan 9, 2008 | 11:35 PM
ford trans tech's Avatar
ford trans tech
you can use your diesel trans you just would need someone to disasemble both transmissions and install the outputshaft from the 4x4 trans into your diesel trans
Old Jan 10, 2008 | 12:22 AM
David85's Avatar
David85
For all the trouble of tearing down the transmissions, you may as well put a rebuild kit in there. Parts for the E4OD are not very expensive, I got many good upgrade parts off Ebay stores, but tearing into an E4OD is not for the faint of heart, and you need a good manual to do it. The tailshaft is held in my one of the most evil snap rings ever conceived, bring a full vocabulary when it comes time to pull the output shaft.
Old Jan 10, 2008 | 03:14 AM
GPSMatt's Avatar
GPSMatt
u can always get a divorced np205
Old Jan 10, 2008 | 03:35 AM
greythorn3's Avatar
greythorn3
u can use a pathfinder adapter to convert a c6 2wd to a c6 4wd then you dont even have to take the trans apart!
Ray
Old Jan 10, 2008 | 03:37 AM
archangel's Avatar
archangel
Originally Posted by David85
Parts for the E4OD are not very expensive?
HA!
HA, HA, HA, HA!
You must be rich!
Or I should say compared to what?!
Old Jan 10, 2008 | 10:24 AM
Franklin2's Avatar
Franklin2
Ray
I did a web search and can find nothing on this? Who makes it?
Old Jan 10, 2008 | 01:03 PM
David85's Avatar
David85
HA!
HA, HA, HA, HA!
You must be rich!
Me rich? OK, that is funny.
Price wars on Ebay have driven the cost for many stock and upgrade parts down, although billet TCs are often still up there (sometimes found for $350). Used parts can be had for very good prices, and I got a few myself (like new condition).
If he is going through the trouble of making a good truck out of two donors, then why not but an overhaul kit in there if you are tearing the trannies down anyway? Overhaul kits are usually $100-$200, I paid $50 for a transgo shift kit/ correction package, had many goodies in it.
Old Jan 10, 2008 | 02:51 PM
ghunt's Avatar
ghunt
I'm more curious as to what you plan to do with the suspension on that F150 to hold up a diesel engine.
Old Jan 10, 2008 | 03:59 PM
greythorn3's Avatar
greythorn3
who makes it? PATHFINDER!
Ray
Old Jan 10, 2008 | 07:59 PM
89toyhauler
Thanks for input helps a lot i think that i may have found a diesel 350 4x4 with no motor goning to look at it tomorrow. But i don't get that one i'll just make it two wheel drive for now and wait for a 4x4 trany and the suspention i'm just gona put some 250 coils in and keep my foot out of it so nothing breaks. It's just gona be a daily driver i already have a 02 550 for towing.
Old Jan 11, 2008 | 10:36 PM
ford trans tech
E4OD parts are not that expensive i guess it depends on who you buy yours from , and i get a chuckle from many of those upgraded parts for big buicks , the only part that needs upgrading is the torque converter, beyond that a pump modification kit and a solid rebuild
Old Jan 11, 2008 | 10:59 PM
David85's Avatar
David85
Agreed, most of the "upgrades" are actually ford OEM, like the steel planetaries, and higher displacement pump. The aftermarket imput and output shafts are very expencive, along fancy clutch packs but I don't think they're needed in the real world. I've taken heat for saying this before, but I still say the E4OD can be as tough as the C6, or even better, but early years could use some work.
mercaprirs
Oct 1, 2010 07:54 AM
Glockem45
Sep 1, 2009 09:08 AM
Boonebird
Apr 28, 2008 11:12 AM
Gai
Sep 21, 2001 08:33 PM
